Home Racing World • View topic - homemade fresh air intakes and radiator hoses now with pics!
Postby btaylor » Thu Jul 31, 2014 11:54 am
For those of you that like a little scale realism,this a quick cheap add on to a jalopy engine for radiator hoses,or a vintage fresh air intake for the driver.or even some old fashioned flex pipe exhausts!
1.You need to save your old click type ink pens to get the springs out of them.
2. You need a piece of heat shrink tubing that just fits the spring
3. a piece of coat hanger or mechanics wire or any bendable metal that fits thru the spring.
Put heat shrink over spring,put wire thru the spring and bend to suit your project.
heat with a lighter or heat gun till you get the tubing down to the size of the spring.
Pull out the wire,pull out or unscrew the spring (sometimes you cant save the spring) with needle nose pliars
And there you have a nice radiator hose or in this case,a driver forced air intake that stays in the shape you bent it! And if you want the same look as the new carrera charger has on it,slide a piece of brass square tube up to the end of the spring,and cover it with shrink tube as well,now you have a square mount at the front of your vent.
There are many different colors of shrink tube,so you can get the color you might want,or paint them.
Looks like mini dryer vent tubing when finished.
This is a quick driver air intake with the square opening
Re: homemade fresh air intakes and radiator hoses
Postby dreinecke » Thu Jul 31, 2014 11:57 am
Bob,
That is a great tip - thanks for sharing it!
I suppose that means you'll have this in the Falcon, right? ;)
Postby btaylor » Thu Jul 31, 2014 12:09 pm
Postby demether » Thu Jul 31, 2014 12:10 pm
Really clever idea ! I've got both items and never thought doing this !
demether
Re: homemade fresh air intakes and radiator hoses now with p
Postby btaylor » Thu Jul 31, 2014 5:48 pm
pics added
Postby btaylor » Thu Jul 31, 2014 6:18 pm
Postby demether » Fri Aug 01, 2014 11:59 am
The chrome intake is painted ? The chrome effect is really good !
demether
Postby btaylor » Fri Aug 01, 2014 12:34 pm
Postby btaylor » Fri Aug 01, 2014 5:50 pm
example of fit on 1/32 small body car
Postby TuscoTodd » Sat Aug 02, 2014 5:52 am
That is too cool! I am going to have to try that! :D
Postby Dangermouse » Sat Aug 02, 2014 6:48 am
sweet!
Dangermouse
