Urethane tires?
Sun Jul 27, 2014 8:23 am
by btaylor
Is it normal for urethane tires to coat the inside of your slot car body with loads of fine powder?
I just built a stocker with the PG supewide tires,and the tires are seemingly shredding.They are not touching anything but the track,no body or chassis rub. I'm using an M/T-5 motor,and its slides out thru the corners pretty good.
Just curious,as I have not used these before.
Re: Urethane tires?
Sun Jul 27, 2014 8:26 am
If they are not trued they will sometimes "sand themselves" as you put miles on them. A lot of times it happens when I forget to contour the outer and inner edges. Leaving a hard edge on them can lead to that.
Re: Urethane tires?
Sun Jul 27, 2014 9:16 am
by btaylor
Thanks Harry, I don't have a razor yet,But I trued them the old fashioned way,then swapped the rear to the frt and trued those also, I did not however do anything as far as the outer contour goes,That must be it. I cut back on my track power from 12 to 11 to see if I was just spinning them up to much, the car is a bit heavy ,could that cause some of this as well?.
Re: Urethane tires?
Sun Jul 27, 2014 9:22 am
It could, your surface seems smooth enough but no matter how smooth you can sand them if you give them enough spin.
My cars have just a hint of a few "marbles". I thought I trued them...but noooooooo, my track is finishing the job :) In truth when I am drifting over the braid/slot I am likely catching it a little. But not a lot...they should last about 3 or 4 years at this rate :)
Re: Urethane tires?
Sun Jul 27, 2014 10:09 am
You did not say what sort of track you are running on. I have no experience with Paul Gage tires, but I have run Yellow Dogs quite a lot and while they do wear a lot faster than silicone tires they should last a reasonable amount of time. I believe that two different compounds of Paul Gauge tires are available, PGTs are Shore 40 and XPGs are softer, Shore 20. I would expect that the XPGs would wear faster in most cases. If your cars want to slide around a lot they will probly wear out ther tires faster than if the cars were more stuck down.
Re: Urethane tires?
Sun Jul 27, 2014 10:14 am
by btaylor
Re: Urethane tires?
Sun Jul 27, 2014 12:41 pm
by btaylor
UH-OH! BUSTED! :laughing-rolling: That wasn't me Dave, somebody hacked my thread! ....or something like that :oops:
Re: Urethane tires?
Sun Jul 27, 2014 3:42 pm
by dr fabio
Urethane tyres wear quite fast compared to rubber and silicon. The marbles stuck to the inside of your body is quite normal for urethane tyres. I have this on the inside of my cras for both 1/32 and 1/24.
