To help secure some parts you can combine the pins with craft wire.
It goes right through the bottom and then you can twist it tight using a needle nose pliers.
I just set the block on the table edge or just as is, it's not going anywhere.
Works great when you want to make sure the parts are together as clean and flush as possible. Beats my old "lay the big hammer" on it :)
