Page 1 of 6
Re: Kurtis-Kraft scale drawings
Thu Dec 05, 2013 8:20 pm
by whitworthnut
Dave
Check out this site and email the fellow. Maybe he'll share his plans. Never hurts to ask.
Thu Dec 05, 2013 9:59 pm
by whitworthnut
Thu Dec 05, 2013 10:15 pm
Sounds like a fun and challenging plan Dave.
Fri Dec 06, 2013 4:34 am
by Wolseley Hornet
Fri Dec 06, 2013 10:25 am
by Wolseley Hornet
Blimey! It's even smaller than a Mini!
Nerf bars and all the other shiny bits could be made out of fine brass rod (= easier soldering).
The tiny can motor out of a Carrera go might fit.
Time to tap into the expertise of the 1/43 boys.
David.
Fri Dec 06, 2013 11:12 am
by whitworthnut
Fri Dec 06, 2013 11:19 am
by whitworthnut
Dave,
Make sure you resize the image to print. The forum scales them down.
Fri Dec 06, 2013 11:54 am
by whitworthnut
Beats me Dave. I did the same thing. The printer spit out about 5 blank sheets and an oversized image. Even when I print from my FTP site, it's wrong. The body should be 3 11/16" long. When I print it out directly from photoshop, it's right. If you give me your email address, I'll send you the jpg and see if that works.
Fri Dec 06, 2013 12:12 pm
by whitworthnut
How did you get it to size correctly
Re: 1/32 scale Kurtis-Kraft Midget, carving has begun!
Sat Dec 07, 2013 10:40 pm
Nice work so far :)
Sun Dec 08, 2013 2:54 am
by Wolseley Hornet
Looks great.
Soon be time to seal and sand . . .
What will you use? I used cellulose-based sealer for the Morgan (yes, it's still a work in progress - just got distracted for a while with Autograss Minis!).
David.
Sun Dec 08, 2013 10:49 am
by Wolseley Hornet
The stuff I used first was simply called Sanding Sealer.You had to use cellulose thinner to clean the brush. It dried very quickly to a hard clear surface which was easy to sand.Once it was the right shape( and I guess in the case of the Midget, when the panel lines are scribed), I did a couple of coats of automotive filling primer with sanding between;the a couple of coats of regular primer, with more sanding. I suppose some of this might have been beginners overkill, but it did result in a smooth finish with no sign of woodgrain showing through.
One thing, though; if you don't make sure the ventilation is good, you can feel the solvents dissolving your brain!
I'm not sure that you can get cellulose paint here any more, but I guess no-one much cares about the brains of aero-modellers.
David.
Sun Dec 08, 2013 11:01 am
by dreinecke
Nice work so far!
Sun Dec 08, 2013 11:14 am
by Wolseley Hornet
David. It's just occurred to me; why not ask woodguy32 what he uses as a sanding sealer. Working with wood is his stock in trade, and he's been showing pictures of carved masters on here for years?
David.
Sun Dec 08, 2013 4:12 pm
by Derby City Speedway
