Greetings, thanks for your kind comments and views. Well it looks like an oil line leak it is. Learned a lot about putting a wash on. Hope for better results next time.
Harry, Protoslot wheels are fine wheels, however a caution should you use them. Make sure the grub scew is going in straight becasue the hole in the wheel strips out real easy, however if that happens 2 part epoxy glue holds them real well to the axle.
Bibster, here in Northern Michigan the time between end of summer and ice fishing season is car building time. Plus I have found now that the Detroit Lions have gone back to their old ways of playing horrible football that most of my Sunday afternoons are free. Can't stand to watch a 4 hour live horror show.
David, if your car leaves the box find a hazmet suit. I have never seen so much resin dust in the air. I wore an old rain suit and a dust mask and still looked like I had spent the day in a mine. Just took the suit off, dropped it in a plastic bag and threw it out. I have 3 more AA bodies and they are all the same.
Dangermouse, David, The product you mentioned is what I used. They are plastic, at least the set I have, and kind of hard to use. you might want to take a look at this site,
http://www.scalehardware.com/. Their rivets are metal and look like they might be easier to use. I ordered up some sets of different size and should get them in the next day or so. I'll give you an update when they arrive.
Regards, John
