Home Racing World • View topic - Body post
Body post
Body post
Postby Almafan 55 » Sat Oct 12, 2013 8:56 am
What different ways to make body post? I know SSC has theirs, but would to see other ways also. Pics would help. Also, what do you do with striped out body post, not broken just the screw won't tighten up or vibrates loose? Thanks
Almafan 55
Re: Body post
Postby transam6870 » Sat Oct 12, 2013 9:03 am
when I strip a post I fill it with super glue and redrill it and its good as new
transam6870
Re: Body post
Postby chappyman66 » Sat Oct 12, 2013 11:05 am
You can use superglue, JB Weld, or even a few drops of resin if you are casting a body. They will fill the post so you can re-drill later.
You can also replace them with plastic rod, or with several sizes of tubing telescoped together.
Re: Body post
Postby cagee13 » Sat Oct 12, 2013 11:28 am
cagee13
Re: Body post
Postby whitworthnut » Sat Oct 12, 2013 12:05 pm
whitworthnut
