Home Racing World • View topic - Fixing Chassis' to bodies on Scratchbuilts
Postby whitworthnut » Fri Mar 01, 2013 12:23 pm
whitworthnut
Re: Fixing Chassis' to bodies on Scratchbuilts
Postby whitworthnut » Fri Mar 01, 2013 1:08 pm
Thanks Bibster. Pretty much as I thought. Trial and error. The styrene tubing method looks like it would work well
whitworthnut
Postby whitworthnut » Fri Mar 01, 2013 2:02 pm
That looks like a foolproof solution with no trial and error. Thanks Bibbster
whitworthnut
Postby waaytoomuchintothis » Fri Mar 01, 2013 2:23 pm
Phil at Slotcar Outhouse is a whiz at building chassis for unusual bodies in tight scale applications.
http://slotcarouthouse.com/viewforum.ph ... d73f2d744b
Postby whitworthnut » Fri Mar 01, 2013 3:02 pm
Thanks Rob. Some good stuff there.
whitworthnut
Postby MoparGreg » Fri Mar 01, 2013 3:05 pm
I usually use wall plugs glued to the under side of the body. Then use screws, screwed through the chassis into the plugs. It works for me & cheap.
MoparGreg
Postby gascarnut » Fri Mar 01, 2013 4:08 pm
There are lots of ways to do this, apart from the regular central posts:
1. Pins, like the 1/24 scale commercial cars:
2. Countersunk holes for flat-head scews on the sides that screw into plastic tube in the body:
3. Screws through the side pans that screw into a threaded plate that is stuck to the body sides via some dense foam:
gascarnut
Postby whitworthnut » Fri Mar 01, 2013 4:44 pm
Dennis
That's excellent. Gives me a bunch of options. I've just ordered the Aston kit and I'll see which one works best on it when it arrives. Many thanks everyone for your contributions.
whitworthnut
Postby DHansen » Sat Mar 02, 2013 9:09 am
And this guy uses magnets.
DHansen
