1/25 CHEVY TRUCK BUILD, PIC HEAVY
Postby Beach Oval » Tue Feb 19, 2013 6:50 am
Starting a 1/25 CHEVY TRUCK on a 1 CUT WOMP CHASSIS.
More pics as build progresses.
Beach Oval
Re: 1/25 CHEVY TRUCK BUILD
Postby proxieken » Tue Feb 19, 2013 9:11 am
Is that an S-10 truck or full size?
I am curious to see how the parts fit in the truck bed. I want to build a truck someday but I keep thinking it will need a bed cover.
proxieken
Postby Beach Oval » Tue Feb 19, 2013 12:53 pm
It is a NASCAR TRUCK kit I am using, so it is a FULL SIZE PICK UP proxieken.
Nice bibb, maybe some flat styren sheet if you wanted to make and put a bed cover on.
Beach Oval
Postby Beach Oval » Tue Feb 19, 2013 3:43 pm
WOMP CHASSIS with 3/8" Hole for MOTOR VENT COOLING./i]
[i]My 1 CUT to STRETCH.
STRETCH on BUILDING JIG to 4.5" WHEEL BASE, using .055 PIANO WIRE. SLICK 7 1/8" AXEL BRONZE RACING BUSHINGS SOLDERED IN REAR.
Beach Oval
Postby Vintage 1/24 » Wed Feb 20, 2013 7:47 am
I will be watching this - I am building a very similar chassis for my Ford Falcon - to run as a Street Stock at South Shore Speedway.
It looks like you are going to build this in that "Street Stock" spec - with bronze bushings in the "stock" Womp location and 1" tires?
That truck should be cool - maybe just run some wide black cloth duct tape as a tonneau cover or use really thin styrene - keep it as light as you can for a full size truck... The body already is pretty wide so that works well for the Womp pan.
I will look forward to see how this one plays out.
Vintage 1/24
Mr. NY Modified
Postby Beach Oval » Wed Feb 20, 2013 8:47 am
Yes Ron, same set up as a STREET STOCK CHASSIS. The BRONZE BUSHING is better than the standard PARMA.
Going to set TIRE HEIGHT up at .950 to get a little lower.
MOTOR will be a PARMA SEALED 16D DEATHSTAR with a ARP 8 TOOTH ANGLED PINION and a PINK PARMA 35 CROWN.
We use to run a Truck class, MOTOR, TIRE and GEAR RULE. Was some of the best Racing we had. Plenty of BANGING and being a little TOP HEAVY, you had to DRIVE the Truck.
I have 2 already from years past, but my Building has become CLEANER and a little better since then. Since I have Kits and all parts needed, what the hell, I was going to do another STREET STOCK, but how many of those do I need? Guess you can never have enough!
Beach Oval
Postby SpeedyNH » Wed Feb 20, 2013 6:58 pm
nice. but an 8t angled pinion for inline? (assume 48p)
SpeedyNH
Postby Beach Oval » Thu Feb 21, 2013 7:26 am
Hi Speedy,
Thanks, Yes, I am using 48p.
Beach Oval
Postby Beach Oval » Thu Feb 21, 2013 7:45 am
Soldered Piano Wire in place, after that, I Soldered a Brass Plate on Bottom of Chassis to get some Low Weight as I will be using a Taller Tire and this will also let me have my 1/16" Clearance on Tech Tool.
On the Left Rear Section of Chassis, I soldered a Strip of Brass that I Soldered Weight on. It just Lays across over onto Front Part of Chassis and this will transfer Weight down onto front part of Chassis while Accelerating.
YES, when you see all the Weight your going to be saying that it looks awful HEAVY. It works well in keeping in Slot, gives it some extra ROLL when Power is Shut Down which helps as the ROLL COUNTS when we race and makes it easier to drive, we are running @ 12 to 13 Volts as we like to be HARD and FAST, plus when you CRASH, :banana-rock: !
Beach Oval
Postby Vintage 1/24 » Thu Feb 21, 2013 3:31 pm
BeachOval-
That sure does look like a lot of weight!
Are you buying the .950s "off the rack" somewhere or are you cutting down 27mm ProTracks?
I figure that angled pinion is a Beach Oval Corporate secret or something - but I like the plate on the bottom and the weighted lever plate - looks like a good design.
- Vintage 1/24
Vintage 1/24
Mr. NY Modified
Postby Foamy » Thu Feb 21, 2013 5:04 pm
If you have a car with the motor not on the exact same line as the axle, an angled pinion will give you a quieter gear mesh. Noise is wasted power after all. . .
Foamy
Postby Beach Oval » Thu Feb 21, 2013 6:09 pm
Ron, I'll probably cut down some 27mm so I can use Wheel Inserts.
The Angled Pinion is not a secret, had a hard time converting @ $6.00 a Gear. Worth every cent as it is a much better Gear Mesh.
And as Foamy said; "an angled pinion will give you a quieter gear mesh. Noise is wasted power after all. . ."
Did you wonder why some of us have Cars that run Quiet? That's the TICKET.
Leadfinger, your welcome. Glad your enjoying the build. Pics are a great guide line to help others and maybe bring out new ideas.
Hopefully I'll get in the DUNGEON tomorrow to get some more work done. Want to add some more Brass on side of Chassis and then it will be Mounting the Body to Chassis and a quick mock up of Assembly.
Beach Oval
Postby Beach Oval » Fri Feb 22, 2013 3:57 pm
OK, Body is mounted! I have pics that I will post when I get my PC back from the shop.
Truck is coming a long very nicely.
To help the side play for the body on the chassis, I put Brass Square Vent like tubing Soldered along the sides of the Chassis and then Bent the Rear Outward before the Rear Tires and they became the Exhaust Dumps.
Next will be Glueing the Body together and Painting and Decaling it up.
Beach Oval
Re: 1/25 CHEVY TRUCK BUILD, PIC HEAVY
Postby Beach Oval » Wed Feb 27, 2013 10:16 am
Body mounted and Glueing Pieces together.
Beach Oval
Postby Vintage 1/24 » Fri Mar 01, 2013 7:36 am
That truck body really works well! - Wide enough to handle the Womp Womp width with ease, and the front end encloses the guide completely and already has a spoiler - all sitting about 1/16" off the track - for a super clean look.
Would you race this in the Street Stock class at SSS or... ? I can see by the what is left of the sidewalls you have the tires turned down to meet the new SSS .940" minimum diameter limit (an odd number choice I think?).
It works so well I want to build one up - Really looks great - Make sure to show a pic after paint and decals...
Vintage 1/24
Mr. NY Modified
