SCC body post repair kit in new build
Tue Oct 08, 2019 9:13 pm
by Mickey thumbs
The SCC body post repair kit is great for the old fashioned wood block body mounting technique. I mounted a static kit Corvette body on a brass pan chassis using their 1b set. Drilled & countersunk the screw holes in the pan. Then drilled 1/8” holes in wood blocks, countersunk to allow flange of threaded acceptor to sit flush. Secured in block with a bit of epoxy. Blocks glued to the inside of door panels. Allows for unlimited removal / replacement of body. Very clean!
Re: SCC body post repair kit in new build
Wed Oct 09, 2019 5:49 am
by 73emgee
Any pictures???
Wed Oct 09, 2019 8:36 pm
by Mickey thumbs
Will post some tomorrow.
Thu Oct 10, 2019 1:25 pm
by Mickey thumbs
Fri Oct 11, 2019 9:03 am
by bill from nh
That body repair kit worked nicely for your application. Am I correct in assuming that '63 Vette body is 1/32nd scale? If you don't mind, could you sometime also post a topside photo of your brass pan chassis? I have a chassis fetish & like to see what's going on topside too. :text-thankyouyellow:
Fri Oct 11, 2019 7:32 pm
by Mickey thumbs
Yes, bill. It is a 1/32 scale amt static model with a one piece body I picked up at the local Hobby Lobby. The chassis uses a slot.it SW pod as I wanted it to be competitive with other cars in their Classic series and it is. Only my second scratch build since returning to the hobby, but I’ll post a picture tomorrow.
Sat Oct 12, 2019 10:06 am
by Mickey thumbs
Sat Oct 12, 2019 3:19 pm
by bill from nh
Mickey, thanks for the additional chassis photos. As time goes on, you'll find that the more you build, the better you'll get. But always keep in mind that you don't race looks, you win a race by how well your car handles. It sounds like this one drives just fine. <lOL> If you ever become concerned about this car's weight, you got plenty of sheet brass for drilling lightening holes. Likewise, you could always use holes & lead if you wanted/needed to change its weight distribution around. I did find the other photos of your Vette body in the other thread. I don't go to Hobby Lobby often, but next time i'm there, I'll check out their model car kits.
