1966 Eldon Ferrari p3 Finished!
I have had a few of these bodies around for a while now. I wanted to build an early (66) P3 that didn't have the shark vents behind the rear wheels. I think this Eldon body can be made to look the part pretty well. It will be red of course, and plans call for full lighting and clear glass (vac formed from the original smoke version). So far it is a parts box build, and actually runs quite well. The chassis is my old stand by Artin, cut down to fit the body. Wheels are Cartrix BMW. They look pretty close to the thick 5 spoke wheels on the 1:1 car. they will be gold centered. axles are slot it,motor is a Ninco I believe, it checked at around 17,00 rpm, and runs close times to my others in this series. Tires for now are a mix of silicone fronts, and rubber Monogram rear. I will be replacing them with PG tires. Its already a fun car to run, so it should be a nice addition when finished.
