Home Racing World • View topic - The minimums
The minimums
The minimums
Postby CJR » Sat Jan 30, 2016 6:37 am
I am jumping in now. Ordered the NEW Torino Dust Up set. But I want to scratchbuild too. My last slot car experience was in the early 80's. The set looks awesome but I do want to build my own cars too. What are the minimal tools and equipment needed to get started?
I know a soldering iron and exacto knives and a dreml tool. But is there a recognized best size or brand honeycomb jig?
CJR
CJR
Re: The minimums
Postby bill from nh » Sat Jan 30, 2016 8:10 am
i don't think there is any "best brand" of honeycomb plates(jigs). A lot of sources seem to be around now. Mine came from a Florida jewelry supply house, because at the time, they had what I wanted for less than $10. As for size, if you get one roughly 5"x7" it'll be big enough to build both 1/32 & 1/24 scale. If you'll only be building 1/32, you can get by with something smaller. In any case, be sure to read the above thread on the honeycomb jigs. It has lots of good information. For a Dremel, I suggest a corded model. For me, they last longer than any battery powered models have. But I will admit to not buying either type in the last 10 years. For solder, get some rosin core 60/40. If you have a Radio Shack store in your area, their solders have always been good. If you'll be working at all with piano wire or other steel parts, buy some acid flux. If you'll only be working with brass, a can of paste flux will fit your needs. These tips should help you get started, but if you have other questions, don't hesitate to ask them. This site has a group of very good chassis builders. Have fun as you build! :)
bill from nh
Re: The minimums
Postby goosenapper » Sat Jan 30, 2016 11:34 am
goosenapper
Re: The minimums
Postby nhdungeonracer » Sat Jan 30, 2016 3:07 pm
Re: The minimums
Postby CJR » Sat Jan 30, 2016 5:07 pm
Thanks for the information and advice. I do read as many posts as possible as I research and learn. My short term goal is to gather the basics, so I can create my own and join some of the fun. I am not sure when I'll get started but my first planned build will be for the world famous Show Me Showdown (2017).
CJR
