Inlet stacks
Inlet stacks
Postby munter » Mon Nov 30, 2015 11:50 am
Some time back I did these three types in resin.
Not easy to get a good result but they are light and could be helpful in a build of a CanAm car of some type.
Oh I see a fault and a blur in one pic....early morning fuzziness, sorry.
Re: Inlet stacks
Postby RazorJon » Mon Nov 30, 2015 11:58 am
those look nice
Re: Inlet stacks
Postby waaytoomuchintothis » Mon Nov 30, 2015 1:28 pm
Those must be a bear to get out of the mold! Very well done.
Re: Inlet stacks
Postby chrisguyw » Mon Nov 30, 2015 2:14 pm
Hi John, The middle set in your first pic., appears to be from the the Rev.Mono MK6 ??....if so, I would love a copy or two.
Please let me know, and we can arrange something.
Chris Walker
chrisguyw
Re: Inlet stacks
Postby CrockettNZ » Mon Nov 30, 2015 2:27 pm
now why did you not show me them last night when I was around at your place
I would be keen on the middle one in first pick
CrockettNZ
Re: Inlet stacks
Postby red73mustang » Tue Dec 01, 2015 1:47 pm
+1 on that middle set of McLaren M6 injectors~! I see a set in my future !
red73mustang
Re: Inlet stacks
Postby frank9129 » Tue Dec 01, 2015 3:33 pm
I have a La Cocaracha which had the stacks cut out to make room for the motor to cool.
Do you have a set of stacks which will fit?
frank9129
Re: Inlet stacks
Postby munter » Tue Dec 01, 2015 8:30 pm
Hello Frank. Can you measure the exact dimension of the hole to fill?
red73mustang....I am working on a package to the US with some of these so a bit of wait is involved.
Re: Inlet stacks
Postby frank9129 » Sun Dec 06, 2015 11:04 pm
Munter,
My La Cocaracha has a hole 4cm x 2.5cm.
Some of the motors got a little how back in the day. This is a car that I was given so I can't tell the whole story. All I can tell you is that this is an original not a replica. REH sells the remakes.
I want to put it back into operation. The Track in Gaithersburg, MD will be the place to test it out.
frank9129
Re: Inlet stacks
Postby padirtfan » Mon Dec 07, 2015 9:49 am
The middle one has dirt modified written all over it......
padirtfan
Re: Inlet stacks
Postby munter » Mon Dec 07, 2015 12:11 pm
@Frank9129 the larger two sets of stacks I have, use a smaller base than the hole you describe. A plastic base plate and then the stack set would have to be put together and stuck in if you wanted to use either of them.
@padirtfan...I think you are right but they would also suit a few early CanAm cars too.
Re: Inlet stacks
Postby frank9129 » Mon Dec 07, 2015 3:44 pm
Munter,
Drop me a PM as to how much I owe you for a set of stacks. I'll build up the bottom first.
My address is : 283 Hillsmere Drive Annapolis, MD 21403 to calculate the postage.
frank9129
Re: Inlet stacks
Postby Alaskaracer » Wed Dec 09, 2015 1:20 am
I think a set of those would be awesome for a gasser drag car!
Alaskaracer
