Indycals
Re: Indycals
Postby HomeRacingWorld » Sun Nov 01, 2015 1:20 pm
Thanks for the reminder...lol, I needed it.
Re: Indycals
Postby mattb » Sun Nov 01, 2015 3:25 pm
Same here, Indycals makes great stuff and lets a guy build lots of colorful cars. Beside the 1/24 cars I have been casting and building, I am just finishing some re-paints and decalling of the 1/24 Eldon Indy cars. They came out great and I'll put some pix up in a day or two. Those Eldon cars are really overlooked. A little small for 1/24, but not badly detailed cars at all.
Re: Indycals
Postby goosenapper » Sun Nov 01, 2015 4:49 pm
The decals really are great- crisp, opaque, and they give you enough time to position them properly before adhering to the model. You have to trim them because the decal sheets are not pre-cut, but that's no real issue. He's got decals for other cars too, and was really helpful in creating a sheet of just striping so that I could adapt the Indy Interscope decals for use on this 1/24 Ferrari:
Unfortunately you can't see him too good in this shot, but that's a Shotgun Dave driver figure in there behind the wheel. Thanks, Dave!
goosenapper
Re: Indycals
Postby mattb » Sun Nov 01, 2015 5:14 pm
I finished one Novi and have a second one partially decalled. If you find an easy way to put those red pinstripe decals on, let me know! I think it might be easier to just draw them on with a fine point sharpie!
Re: Indycals
Postby TuscoTodd » Sun Nov 01, 2015 5:43 pm
Thanks for the heads up guys! I have never used their decals - but after seeing those examples - I am definitely going to have to check them out!
:text-bravo:
Re: Indycals
Postby mattb » Sun Nov 01, 2015 7:06 pm
I cut them into smaller pieces!!!
Re: Indycals
Postby loosewheel » Sun Nov 01, 2015 7:14 pm
They make a great line of F1 decals also!
loosewheel
Re: Indycals
Postby WB2 » Sun Nov 01, 2015 7:28 pm
Has anyone tried Indycals tire decals on a slot car?
WB2
Re: Indycals
Postby WB2 » Sun Nov 01, 2015 8:53 pm
Neat.
I wish someone made decals to match the stock tires on slot cars. It's hard putting PGTs on something like a Carrera DTM and losing the Hankook sidewall lettering.
Then again, the manufacturers could use urethane from the start....
WB2
Re: Indycals
Postby mattb » Thu Nov 05, 2015 9:47 am
Before I started casting the Monogram Lotus and AMT Watson, I had thought to cast the Eldon 1/24 Indy cars. Thjankfully I didn't cast them but the better, more scale other cars. I thought the Eldon cars could be finished a lot better then most of their products and here are a couple I refinished and used Indycals on.
Cars have either scratchbuilt chassis or Dynamic inline.
Re: Indycals
Postby gaborart » Sat Nov 07, 2015 11:40 am
Indycals ROCK!
You've probably seen this before but here's a F5000 Lola I built using his Boraxo decals:
gaborart
