Home Racing World • View topic - sideways rig for the can am
Postby btaylor » Fri Oct 16, 2015 6:12 pm
Had to jump on the sidewinder band wagon, as I had never done one before. I liked all the designs I saw, but wanted something a bit different. don't know if its a winner or not, but it is as easy a build as could be. Of course it still needs all the small stuff, guide mount, side pans etc. but the basic chassis rails are done and solid.
I took two sections of .064 x 1/2" brass, cut to four inches long to start. I then put them on top of each other and did the layout for motor mounts and axles using a 1/4" centerline splitting the side rails. Center punched and drilled the holes, then soldered in the axle tubes.rear tube cut for motor clearance, and added 3/16" bearing collars. the side rails will be drilled to reduce weight if needed.This design is old as slot racing itself, as a lot of very early cars had similar arrangements. it worked then, should work now.(I hope) :lol: Its no WISE engineering job, but it will do. Image
Re: sideways rig for the can am
Postby HomeRacingWorld » Fri Oct 16, 2015 8:06 pm
Trust me, you don't want anything from WISE Fabrications. :)
Nice indeed, how did I know you would have yours almost done? I take The General out for a nice fancy TGIF dinner (Taco Bell) and come back to this :)
Postby chappy » Fri Oct 16, 2015 9:49 pm
Looks great Bob.
You've been holding out on us haven't you lol
Postby dreinecke » Fri Oct 16, 2015 10:24 pm
That is some slick work there!
Postby chrisguyw » Sat Oct 17, 2015 8:38 am
chrisguyw
Postby btaylor » Sat Oct 17, 2015 12:11 pm
Thanks Chris, It is kind of funny, as I was thinking this out, this design kept coming into my head. Probably from back when the Kemtron was popular. My end result turned out to be almost a carbon copy of the ones you posted, and I didn't even consider the drop arm. I made some test runs this AM, and it performs great! The side pans will slide over the posts, and attach the body.Image
Postby Audi1 » Sat Oct 17, 2015 1:31 pm
Postby bill from nh » Sun Oct 18, 2015 10:17 am
Allan, wait a couple more months & they'll be building anglewinders too! :)
bill from nh
Postby HomeRacingWorld » Sun Oct 18, 2015 11:09 am
NO. I refuse! :)
Long live inline!!!
Postby Audi1 » Sun Oct 18, 2015 12:56 pm
SW, SW, SW...........................................sw, sw, sw.........................! :lol:
