3/32 drill blanks
Tue Sep 29, 2015 9:39 am
by dw5555
Anyone have a source for blank longer than the 2 1/4" I'm finding? I need at least 3".
Dave
Re: 3/32 drill blanks
Tue Sep 29, 2015 10:03 am
Tue Sep 29, 2015 11:01 am
by mnfordguy
Hi Dave:
I use McMaster Carr #http://www.mcmaster.com/#8893K133 3/32 SAE O1 Oil hardened rod in 3 or 6' lengths.
I usually get the 6 ft. lengths and share with the guys in our group. This stuff runs pretty straight and true, and it's easy to cut to length with a Dremel.
Hope this helps
Tue Sep 29, 2015 11:20 am
I used precision ground drill blanks for years, and when I tried the ejector pins Jon turned us on to, I never looked back. I use 3/32 & 1/8, and they also come in metrics.
Tue Sep 29, 2015 11:22 am
by RazorJon
I got some, how many you want
Tue Sep 29, 2015 11:32 am
by dw5555
Hey Jon,
2-3" if you got em or anything along that lines till I find out if what I'm making is gonna work.
Dave
Tue Sep 29, 2015 1:23 pm
by munter
Am I reading it wrong?
The McMaster and Carr pin prices seem a little high for my purpose @ $5.40 for a 2 1/2" piece of 3/32 diameter
Tue Sep 29, 2015 1:34 pm
by RazorJon
Pm me your address
Tue Sep 29, 2015 1:41 pm
by RazorJon
PE1-094L14 - 3/32 X 14 Straight Ejector Pin
Unit Price: $6.90
This is from Plastixs.com
That is 14" long
Shipping is a bit expensive so order enough
These pins are ground and are perfect straight
Cuts with abrasive wheel
Tue Sep 29, 2015 5:04 pm
by ming charlie
I found Hobbylinc has 3/32 x 36" music wires 10 rods for $8.39 I don't know if these are strong enough for axles or not
K&S 506 is the number. Hope this might help.
Charlie
Tue Sep 29, 2015 5:10 pm
Charlie, that is the exact ones I use for fronts. So when I get harder axle material, it just lasts me a little longer :)
Thanks for the part# info.
Wed Sep 30, 2015 8:42 am
by dw5555
I have the KS music wire but was a little leery using it because they are going to stick out past the bushings 1/4" before they get to the wheels so close to 3/4" total. Didn't think the piano wire could take the weight of the aluminum wheels and tires unsupported that far out. Especially the rear.
Dave
Speaking of piano wire, I know there are slight tolerance differences so I took a bushing with me the LHS and I was glad I did. They had 3 sets of wires, I couldn't get 2 sets of wire in the bushing, luckily the 3rd set slid in like butter. Pays to check before you buy.
Wed Sep 30, 2015 8:55 am
by mikeinclover
Dave let me know next time you are coming to the store. I think I have some wire here, I bought it when I first got into racing. Don't use it anymore. Not true enough for what we race but I am sure it is good enough for your type of stuff.
Mike
Wed Sep 30, 2015 1:58 pm
by Retro Racer 44
There was a thread some time ago posted, I think by Dodgefarmer. He bought lengths of 3/32 drill rod and cut it to size. The price was really good and you bought either 5 or 10 lengths to a bundle, if I recall correctly.
I will try to find it and post a link.
I always use piano wire, especially on small cars like Sprites or Minis. I guess I'm too cheap to buy Slot.it axles and throw away a third of it.
Keith
ps. Here is the link-
viewtopic.php?f=18&t=11407&p=134505&hilit=3%2F32+drill+rod#p134505
