flared Porsche 356 speedster - build 2
Postby VTECFOUR » Sat Sep 12, 2015 8:49 pm
Starting on a new speedster.
This one's going to use the Devised Designs slimline motor pod, front axle/guide bracket and guide. My last Europa incorporated these and turned out well.
Stay tuned.
VTECFOUR
Re: flared Porsche 356 speedster - build 2
Postby Z-carfan » Sun Sep 13, 2015 12:35 pm
Cool, I have those parts as well and am curious how they turn out.
Postby VTECFOUR » Sun Sep 13, 2015 4:20 pm
Chassis's rolling. Same wheels/urethane tires as my first speedster - Ranch Design, Paul Gage fronts, Fly March F1 rears).
Perimeter chassis's composed of 3/32" square brass and .032" brass strip and attached to DD pod with 2mm Scalextric Sport screws. Will add side pans for additional weight.
Body's mock fitted to get the front and rear tracks set with spacers cut from 1/8" brass tubing.
Should be running soon.
VTECFOUR
Postby VTECFOUR » Mon Sep 14, 2015 1:15 pm
Chassis's running. Added .032" brass pans. Installed a Scalextric FF050 black 30k motor to match Speedster build 1's powerplant. Scalextric Sport 9t pinion and Slot It 28t crown transfer the power.
Runs well with good handling and straight line speed.
Body work is next.
VTECFOUR
Postby VTECFOUR » Sun Sep 20, 2015 11:49 am
Opened up the driver cockpit cover. Salvaged a somewhat triangulated roll bar from another 356 build.
Primer's next. Thinking of a black finish with double silver stripes.
VTECFOUR
Postby chappy » Sun Sep 20, 2015 12:13 pm
As usual Dan , the chassis looks great, as does the car.
Do you use a template for the chassis builds or straight to the jig ?
Postby VTECFOUR » Sun Sep 20, 2015 1:27 pm
Hi Bob,
I just set up the honeycomb jig plate for each new chassis build.
Lately I've had problems with matching left and right wheelbases with builds that require scratch built front axle set ups. So now I position an already "square" chassis beside and run long 3/32" piano wire through the front and rear axle tubes or bushings/oilites. Lining them up has helped reduce my problem.
Later.
VTECFOUR
Postby chappy » Sun Sep 20, 2015 3:37 pm
Cheers for the tip.
Postby SuperSlab » Sun Sep 20, 2015 5:35 pm
Dan, you are definitely the master craftsman for these cars!
SuperSlab
Postby VTECFOUR » Fri Sep 25, 2015 9:44 am
Finished.
Went with a monotone look. Sprayed Tamiya TS40 Metallic Black, accented the headlights and rollbar in Tamiya Lin Gray brush paint and layed down double stripes with silver Pactra trim tape.
Runs well, too.
Another good outcome.
VTECFOUR
Postby Gameover » Fri Sep 25, 2015 9:51 am
Yep that baby is beautiful!
Postby Z-carfan » Fri Sep 25, 2015 3:47 pm
Very sleek!
Postby chappyman66 » Fri Sep 25, 2015 4:15 pm
Very nice build. I love the chassis work, combo of plastic and brass to show all the varieties that can be done.
The black/silver is always a nice look too.
Postby chappy » Fri Sep 25, 2015 5:49 pm
Nicely finished Dan.
