by waaytoomuchintothis » Wed Aug 05, 2015 7:00 pm
Airfix is strict about scale, so don't be surprised if its cramped in there. The kit has a good floor pan that gives you perfect dimensions for a scratchbuilt chassis. The biggest problem with these is the total lack of chrome. You will have to deal with foil or automotive chrome spray paint for that. The kit wire wheel inserts aren't bad for a kit, but you may want to use large wires like Ninco or Scaley to make inserts. The fine wire from BRM is far too small to look right on the car. The Stromy wires (if you can find them) look just fine.
