Home Racing World • View topic - My second resin cast - Fat Fiat Abarth 1000
Postby VTECFOUR » Fri Feb 20, 2015 12:43 am
Seemed liked another opportunity, so I cast the body during my Fat Fiat Abarth 1000 build.
First pop has a good number of voids but I've learned from this. This casting is quite addictive.
Thanks to Luf again for the workspace and materials.
VTECFOUR
Re: My second resin cast - Fat Fiat Abarth 1000
Postby munter » Fri Feb 20, 2015 2:39 am
Postby btaylor » Fri Feb 20, 2015 8:39 am
Nice car, Looks like a great casting too.
Postby Slotcarthumb » Fri Feb 20, 2015 6:11 pm
I was curious about how much casting silicone you would use on a car this size? around a quart?
Slotcarthumb
Postby VTECFOUR » Sat Feb 21, 2015 8:03 pm
The Fiat's casting block took 495 grams of mix, 450 of base silicone and 45 of catalyst. In comparison, my Bullfrog roadster took 220 grams (200 + 20).
Hope that helps.
VTECFOUR
Postby Slotcarthumb » Sat Feb 21, 2015 10:27 pm
So you are slosh molding these? I haven't done A LOT of molding.. but those looked so nice I thought you might be doing a two piece mold...
Slotcarthumb
Postby Retro Racer 44 » Sat Feb 21, 2015 11:34 pm
I poured a Bullfrog from Dan's mould last night, and ran into a problem with some of the resin curing before the rest. So I scooped out the fast and continued to slosh the rest.
Oops! While I got complete coverage of the mould, when I pulled it I discovered it is almost paper thin, would you believe the body weighs 3 grams? I will let it sit for a while to really harden up, then I plan to paint the inside with epoxy to strengthen it. It should work, and I already have a chassis to fit it.
Lesson learned, pour as much resin as needed into the mould right away because any left in the cup sets faster than the stuff you are sloshing. If my plan doesn't work I will just pour another.
ps. A week later. I gave up on that body, it was just too fragile. Once I had decided to, I crushed it like an empty eggshell. I'll just do another, but Dan has more coming down the pipe that just might take priority.
Last edited by Retro Racer 44 on Sat Feb 28, 2015 1:52 am, edited 1 time in total.
Retro Racer 44
Postby Slotcarthumb » Sun Feb 22, 2015 12:23 am
A few things I accidentally sloshed to thin. I layed a little very thin glass cloth in those areas along with epoxy resin as you mentioned. So far so good.
I wish molding agent was free.. It is fun to make things using it.
Slotcarthumb
Postby SLOTTING SINCE 1963 » Tue Feb 24, 2015 12:14 pm
Dan that look's good. Did you use the SCX gulf fat boy for the mould?
Richard.
SLOTTING SINCE 1963
Postby VTECFOUR » Tue Feb 24, 2015 2:54 pm
Richard,
Yes, the SCX is the basis of my fat Fiat cast.
Here's the thread of the original car's build to date.
http://homeracingworld.us/viewtopic.php?f=18&t=10085
VTECFOUR
