Home Racing World • View topic - Attaching windscreen to resin body
Postby Audi1 » Thu Feb 19, 2015 2:52 pm
What's the best way to attach a vac formed clear windscreen to a resin-bodied roadster? I assume some sort of glue, but I'm not sure which one and I'd like to do this right first time........if I can. Thanks.
Re: Attaching windscreen to resin body
Postby Dangermouse » Thu Feb 19, 2015 3:19 pm
I use two glues
Zap Formula 560 Canopy Glue
and a jewellery glue G-S Hypo Cement - this on comes in a tube with a needle tip dispenser
Both dry clear and don't fog up the glass :)
Dangermouse
Postby TsgtRet » Thu Feb 19, 2015 3:31 pm
I use Testor's Clear Parts Cement. It's a white glue that dries clear. It can be used to repair imperfections as well: I bought a used Fly T70 that had a "chunk" missing out of one of the headlight covers....a little bit of this and it's hard to tell it was ever broken.
Postby Audi1 » Thu Feb 19, 2015 3:49 pm
How quickly do these glues dry? I find that vac formed plastic is both flimsy and has a mind of its own. Do you hold the pieces together while the glue sets up?
Postby waaytoomuchintothis » Thu Feb 19, 2015 4:18 pm
I just flip it upside down and put a weight in it. If it needs to be tacked in other spots, I do them after the first attachment is set.
Postby TsgtRet » Thu Feb 19, 2015 4:33 pm
Postby cagee13 » Thu Feb 19, 2015 6:48 pm
I cut my vac formed glass to fit then dip the glass in future. I dip mine at night then the next night I super glue them to the body. Since I've began doing this i have never had a windshield fog and with the super glue it's stuck within a matter of seconds. Just remember if you cut the windshield after dipping it you'll have to dip it again before gluing or it will fog.
cagee13
Postby dreinecke » Thu Feb 19, 2015 9:23 pm
The ONLY glue I use on my glass is Tacky Glue. It is a white craft glue that dries clear, sets quick, and doesn't fog glass.
Postby Audi1 » Fri Feb 20, 2015 5:53 am
Thanks for all the information and recommendations. I'm going to try the 560 adhesive. I'll probably tack down the corners and then run a bead after it's set. I'd forgotten how much modeling there is in scratch building......... I'm liking it, though......
