Lime Rock Park building from Match Sticks
Re: Lime Rock Park building from Match Sticks
Postby turbokev » Fri Apr 11, 2014 10:28 am
Big update today.. My Dad was busy this morning putting together the walls and railings he made...
First, Floor section upside down to install the carriers for the main posts..
Then, wall after wall for the first floor was put in to place..
and then the first floor assembly was placed on to the support posts..
Might be a little while till the next update as he needs to work on the plans for the roof and that center upper room..
I think it's amazing.. I'm so glad he's taken on this project for me :D
turbokev
Postby Ember » Fri Apr 11, 2014 4:32 pm
That's brilliant.
I just showed it to His Lordship who thinks I'm bonkers. I feel so much better because at least I use planks. :)
Postby turbokev » Mon Apr 14, 2014 3:11 pm
My Dad added the ground floor room, as well as some support beams for the main posts..
Rear view of the building..
turbokev
Postby ourwayband » Mon Apr 14, 2014 3:59 pm
Wow,truly an Artist in every sense.
Postby Ember » Mon Apr 14, 2014 4:04 pm
Wowee zowee. I will never complain about waiting for glue to dry again.
Postby TuscoTodd » Mon Apr 14, 2014 4:05 pm
W O W!!!! That is going to be a work of art when it is complete! What a great build and addition that will be to your track!
:text-bravo:
Postby dr fabio » Mon Apr 14, 2014 4:09 pm
That is insane!! Id be giving my track a tidy up and once over to do that control tower justice.
cheers
dr fabio
dr fabio
Postby waaytoomuchintothis » Mon Apr 14, 2014 4:15 pm
I knew a guy who made scale models for an architectural firm for their presentations, and he made huge money at it. His work was no one bit better than this.
Postby SpeedyNH » Mon Apr 14, 2014 5:02 pm
so, Kev, did he build the house you live in, too?
SpeedyNH
Postby DixonJohn » Mon Apr 14, 2014 5:42 pm
That is absolutely unreal!! Very nice work
DixonJohn
"The Mayor"
Postby SRQSloter » Mon Apr 14, 2014 5:52 pm
That is Bad to the Bone Kev.
SRQSloter
Postby Dundee Denny » Mon Apr 14, 2014 7:21 pm
Any sense of the hours he has in the build thus far.
Can't imagine the effort he has put in already!!
Dundee Denny
Dundee Denny
Postby turbokev » Fri Apr 18, 2014 6:12 am
Time for an update~
These are the overhangs that the roof will rest on..
Here they are being glued in to place.. You can see a couple of the photos my Dad is working from..
Here they are in place.. and you can see some supports added as well that go up to them..
Here's the rear view of the building thus far..
I'm not sure if Dad is keeping track of hours spent on it.. He typically works for several hours a day on these projects.
I'm sure it's well up over 100 hours so far~ There's lots of time that goes in to planning, drawing, scaling, and building
sub-structures.. Never mind the intricate assembly of thousands of match sticks~!
turbokev
Postby TsgtRet » Fri Apr 18, 2014 12:34 pm
All that are properly humbled by this impressive work please stand and :clap: :clap: :clap: :clap:
:happy-wavemulticolor:
Postby RV Racing » Fri Apr 18, 2014 12:37 pm
Absolutely stunning work! I've thought about tackling a much more modest matchstick project for my HO layout. In one of the early photos, you show what appears to be a glue tube . . . since your father is clearly an expert, can you recommend a glue for a wood structure project?
Thanks!
Rick V.
RV Racing
