Not your average slot car.............
Re: Not your average slot car.............
Postby DRW21 » Sat Jan 16, 2016 4:36 am
From the rear, the left crown that has no boss and is rivoted to the pulley and drives the left wheel, all these free wheel on the axle.
The right crown is fixed to the axle and drives the right wheel.
The FAAS gear runs freely on the axle.
There are 3x 80 pitch pinions inside the FAAS gear.
These spider pinions are soldered to a one off custom made boss that houses the 3 cut down motor shafts that locate the 3 pinions and the outer part of the FAAS gear (looks like a ring gear) is soldered to this boss. - Dave.
DRW21
Postby walker » Sat Jan 16, 2016 5:37 am
Everything is clear now, thank you very much !
The boss is from brass or bronze, isn´t it ?
Roland
walker
Postby Lou E » Sat Jan 16, 2016 10:24 am
That is too cool, what a work of art!!! If you decide to build another one please take the time to document the build and share it here, I would love to try my hand at this someday.
Lou E
Postby dreinecke » Sat Jan 16, 2016 11:07 am
That is seriously cool! Never saw anything like that before.
Postby Vintage 1/24 » Sat Jan 16, 2016 11:16 am
Love this kind of build!
Very talented scratch build.
If someone wanted to mock up something similar - Some of these kind of parts can be found from 1/24 vintage offerings. The Womp Womp was offered with a factory 4wd setup using pulleys and belts - hard to find an original of course but there are lots of rental belt-drive 'whisper jet' pieces out there that could be used to cobble up a similar setup - all in 1/24 of course.
Also, There was a working differential brass gear set available back in the 60s - offered by 'Tradeship', and works pretty much the way this one was set up. They can still be found, and work pretty well, if you can search one up.
Again very cool build!
Vintage 1/24
Mr. NY Modified
Postby DRW21 » Sat Jan 16, 2016 12:51 pm
Hi Guys, the boss that holds the spur gear is made from bronze, it was a one off piece made by a master machinist for me, he also cut the crown gears as they are also custom made.
I couldn't have done this without his help - Thank You Steve Murch.
Dave (NZ)
DRW21
Postby reek455 » Sat Jan 16, 2016 1:19 pm
Very clever and cool.
reek455
Postby noddaz » Sun Jan 24, 2016 7:15 pm
That is one incredible chassis! Thank you for sharing it with us.
Scott
noddaz
Postby munter » Wed Jan 27, 2016 8:34 pm
Postby HomeRacingWorld » Wed Jan 27, 2016 8:44 pm
Just had the Showdown cars arrive this evening. You are one talented builder. More coming on that soon.
And this is certainly above average.
Postby DRW21 » Thu Jan 28, 2016 2:45 am
Hi Harry, Thank You for letting me know, we're glad they got there and that you are happy to put them thru theier paces.
Damn shame we missed the real run, it looks like it was a real blast!!!
Cheers Mate - Dave
DRW21
