Home Racing World • View topic - Lotus Elite build
Lotus Elite build
Lotus Elite build
Postby VTECFOUR » Sat Oct 25, 2014 6:39 pm
Got going on a new build, a classic Lotus Elite body by Munter.
Sits on a PCS adjustable wheelbase chassis driven by a stock Scalextric S can motor with a 9t pinion and 27t SCX crown on Cartrix metal wire wheels and PG tires. Guide's a Ninco spring one.
Body mounted with Evergreen plastic tubes, SCC 2-56 screw inserts and 2-56 screws.
Inspired by friend TF1250's beautiful green/silver rendition.
I'm thinking white with green stripes for mine.
VTECFOUR
Re: Lotus Elite build
Postby Dundee Denny » Sat Oct 25, 2014 7:17 pm
Your inspiration is a fantastic build in itself!!
Look forward to seeing your version come to life!!
Dundee Denny
Dundee Denny
Postby DAVE » Mon Oct 27, 2014 4:04 pm
This is one I need to do. A friend I used to vintage race with had one, painted the same way, chassis number 1338. Your
model turned out exactly as I remember it. Nice job.
DAVE
Postby VTECFOUR » Sat Nov 01, 2014 1:16 pm
Tamiya white primer's been applied. Detail parts (front and rear bumpers, driver and tray, front and rear windows, headlight lenses) ready for mounting.
PCS chassis with stock Scalextric S can motor runs just fine.
Pure white finish with green stripes and small assemblies to complete.
VTECFOUR
Postby munter » Sat Nov 01, 2014 3:03 pm
I'm liking this...
Postby TuscoTodd » Sat Nov 01, 2014 3:29 pm
WOW!!!! That turned out SHARP!!!
:text-bravo:
Postby dr fabio » Sat Nov 01, 2014 4:09 pm
How did you do the transparent green strip across the windscreen? Im wanting to do that to a Porsche I want to build up.
dr fabio
Postby chris » Sat Nov 01, 2014 9:20 pm
What a fantastic model! The wheels really set it off.
Just changing the subject for a second, Rick asked about the coloured band on the windscreen, I just paint on the tinted laquer from a tin or jar of modellers paint before you mix it.
Chris.
chris
Postby VTECFOUR » Tue Nov 04, 2014 5:12 pm
Sprayed a few coats of Tamiya TS-26 Pure White.
Better let it thoroughly dry before handling the body while fitting those pesky windows.
VTECFOUR
Postby dreinecke » Tue Nov 04, 2014 10:05 pm
Looks great so far. One of my favorite chassis to use for scratch building.
Postby munter » Thu Nov 06, 2014 5:23 am
Postby VTECFOUR » Fri Nov 07, 2014 12:18 pm
Done!
Applied the green stripes cut from green electrical tape. Got the windows in by applying making tape across the frames, fitting the carefully cut windows into the open frames to be held by the tape and toothpicking flowable silicone along the window perimeters to secure them. Turned out better than I had hoped.
Glued in some headlights made from round styrene hole-punched and Lagartijakit lenses.
Finished with taping the interior tray/driver in place, painting details (headlight, signal, tail light, door handle and gas cap) and fitting front and rear bumpers.
Thanks Munter for doing this body.
VTECFOUR
Postby btaylor » Fri Nov 07, 2014 1:28 pm
Man, that is elegant! Very nice looking car. I would be proud to have it in my stable.
Postby munter » Fri Nov 07, 2014 6:12 pm
Looks great but how does it run?
That colour scheme works for me.
Postby dge467 » Fri Nov 07, 2014 6:31 pm
Nice build on the car!!
