Bugeye build 6
Bugeye build 6
Postby VTECFOUR » Fri Jul 04, 2014 12:49 pm
Still got Bugeye fever and have started on number 6, my fattest one to date.
As usual, I started out with a chassis, a Reprotec Fiat Abarth one stolen from my red PRS Mini pick up to be replaced by a scratchbuilt brass one. Nicely equipped with Slot It 21K motor, Slot It 9:27 gears, Ranch Design rims, Paul Gage tires and Ninco spring guide.
Marked off body sides with narrow masking tape, the maximum area to apply 5 minute fast setting two-part epoxy and placed wheel arch masking tape platform.
Started applying epoxy that flows and settles nicely.
Placed body on rolling chassis to set filing contour limits.
First rough filing results.
More filing and sanding.
Getting closer to primer.
VTECFOUR
Re: Bugeye build 6
Postby munter » Fri Jul 04, 2014 2:12 pm
love those arches...must try it on a resin body
Re: Bugeye build 6
Postby HomeRacingWorld » Fri Jul 04, 2014 6:28 pm
Yes sir, this is good stuff.
Re: Bugeye build 6
Postby Retro Racer 44 » Sat Jul 05, 2014 1:16 am
Looks wide enough to go to the new max in a certain proxy, eh?
Keep 'em coming, Dan
Retro Racer 44
Re: Bugeye build 6
Postby VTECFOUR » Sun Jul 06, 2014 12:41 pm
Thanks for the positives.
Got some filler on and did the cockpit cover opening.
Don't think that I'll send this to a proxy. It'll have the kit's miniscule front signal and tailights and I'd be hurting if those got knocked off and lost during racing.
Wouldn't send Bugeye Build 2 for this reason.
If inclined, I'd send this built up Munter resin one, a bit tougher with less small bits attached.
VTECFOUR
Re: Bugeye build 6
Postby FootScoot » Sun Jul 06, 2014 1:57 pm
You are the Bugeye Master! Just great work. :)
Re: Bugeye build 6
Postby dreinecke » Sun Jul 06, 2014 5:57 pm
Gorgeous! Love those things! Great work on the flares too - those are not easy to do!
Re: Bugeye build 6
Postby dge467 » Mon Jul 07, 2014 8:38 pm
Nice work! Those flares look awesome!
Re: Bugeye build 6
Postby ListerStormGT » Tue Jul 08, 2014 5:42 am
Nice work, great looking car and I love those flares!
Re: Bugeye build 6
Postby VTECFOUR » Wed Jul 09, 2014 8:13 am
More progress. Test fitted a driver figure, installed a hoop rollbar and support out of .072 brass rod and did more sanding. Close to first primer coat.
VTECFOUR
Re: Bugeye build 6
Postby VTECFOUR » Sat Jul 12, 2014 8:07 am
Second primer coat on after a bit of putty and lots of sanding.
Ready for final coat, so I'm thinking orange accented with double gold or silver stripes.
Getting there.
VTECFOUR
Re: Bugeye build 6
Postby noddaz » Sat Jul 12, 2014 9:42 am
Those are fantastic! Thanks for sharing them...
Scott
noddaz
Re: Bugeye build 6
Postby VTECFOUR » Sun Jul 13, 2014 7:49 am
Got a couple of coats of Tamiya TS-12 orange on. That turned out pretty bright.
Will follow with some coats of Future finish and a gold or silver double racing stripe down the middle.
VTECFOUR
Re: Bugeye build 6
Postby whitworthnut » Sun Jul 13, 2014 11:06 am
Excellent job, Dan. Well sculpted and nicely finished.
whitworthnut
Re: Bugeye build 6
Postby VTECFOUR » Tue Jul 15, 2014 9:56 am
Done! Got the detail stuff on (rollbar, driver figure, grille, headlights, tail lights, licence plate light) and applied gold Pactra trim tape.
It's my widest Bugeye as you can see the progression in the dark blue, yellow, white and orange builds.
That's enough wide Bugeyes. I've got one Airfix kit left and that'll be a completely stock car.
Later.
VTECFOUR
