by ElSecundo » Thu Mar 13, 2014 6:13 am
This is exactly why I don't recommend an alcohol bath for toy car motors. It isn't that it doesn't work, it's that signals get crossed, somebody does the wrong thing, and *poof* somebody lights on fire. Use water, instead.
When the motor runs, it's sparking as electricity jumps across the air gap at the commutator. So if you start a motor and submerge it into alcohol or naptha, you have a spark, you have air, and you have fuel. If the motor passes through the right concentration of vapors on its way to the fuel, you have a pretty serious problem on your hands.
If the motor starts when it's submerged, you have no air, and combustion won't happen. There are still other accidents that can happen, and if the motor is pulled out of the bath while the armature is still turning, things can get pretty hot. Sure, the odds are low -- but why even take that chance? Use water.
