by BIG E » Fri Dec 06, 2013 10:03 pm
You can see by the crown gear, brass ferrule axle spacers, rear tires, steel chassis, and classic VW womp body that the car is from the late '80's era. I do not think what you've got there is the home set motor (it may not have been available yet). I believe the motor in the photo is the first 16D that PARMA sold in RTR commercial raceway cars that actually held up! I sold hundreds of them back in the late 1980's when I had my raceway. We ran them in midget, "mini-stox", "mini mods", stock womp and flexi-kar races.
I've still got a couple running in "play" cars. The endbell design (and probably an improved armature) is what put this motor over the top, in my opinion. The previous version was inferior in material and design, and had round (cylindrical) motor brushes that created a lot of heat. Between that and the cheap plastic endbell, I can remember the frustration of doing well in a race, only to have the car slowing about halfway through a race and eventually melting down to a standstill !!
The modern PARMA Deathstar and Super16D motor is superior in all ways -- armature, magnets, can and endbell design. They also have both lead wire tabs on top of the endbell.
If you notice in the photo, the white endbell motor has the old leadwire attachment tab arrangement - one on top, one on the bottom at the other side, same as the old Mura motors.
We used to put a small piece of vinyl tape on the chassis of the cars to prevent shorting to the bottom tab. I remember drilling holes through the can into the endbell and using small screws to keep everything secure. We also allowed racers to drill a 1/4" cooling hole in the old steel chassis, as there was none from the factory at that time. Providing that the commutator surface and can bushing both look to be in decent shape, you can hit that motor with some cleaner spray, install some new brushes, oil and fire it up.
I hope this helps you out, have fun with that womp! -- Ernie
