Home Racing World • View topic - Carrera Ford GT Deslots ganging Lanes
Postby fourshipp » Wed Mar 06, 2019 7:34 am
I recently bought a new Carrera Ford GT. It repeatedly deslots when changing lanes. I am running front mag only, have added up to 1/2 oz of lead to the front and 3/4 to the rear. This has improved the overall handling but not the deslot issue. I have tried a blade with the front cut down to a 45 degree angle. This seems to help a bit but does not solve the issue. With the stock blade it will deslot at half throttle.
Of a dozen Carrera cars, this is the only one with this issue. Any suggestions?
Thanks,
Bruce
fourshipp
Re: Carrera Ford GT Deslots ganging Lanes
Postby oldtribefan » Wed Mar 06, 2019 9:20 am
I also had this issue with my Carrera Ford GT and found that, when compared to other Carrera cars, the front blade is mounted up higher than other cars. I shimmed the blade downward so it sat deeper in the slot on the track and this resolved the problem. No more deslotting on lane change.
Kip
oldtribefan
Postby fourshipp » Wed Mar 06, 2019 12:46 pm
Thanks, Kip. About how thick were the shims?
Bruce
fourshipp
Postby BRS Hobbies » Wed Mar 06, 2019 2:32 pm
If you have a tire truer like the Tire Razor, you can true down the front tires to a smaller diameter to get the guide blade lower in the slot.
Brian
BRS Hobbies
Postby HomeRacingWorld » Wed Mar 06, 2019 2:39 pm
Postby Bluevista » Wed Mar 06, 2019 6:59 pm
I had the same problem with my Ford GT, drove me nuts until I figured it out.
I glued a strip of .030" polystyrene to the bottom of the guide blade and all is good.
The car rumbles like crazy, I have sound board and carpeting under the track and the thing still sounds like it has studded snow tires on it.
Bluevista
Postby fourshipp » Fri Mar 08, 2019 6:52 pm
fourshipp
