Home Racing World • View topic - Detailed wire wheel inserts for 1/25
Postby btaylor » Mon Jul 16, 2018 4:04 am
Thought I would share this little trick with everyone. Those old Strombecker wheels that came on all of the early cars, can be transformed into some intricately detailed wire wheels for 1/25 sports and racing cars. the original wheel has an 1/8" axle, and that helps center the insert. They are almost a press fit in H&R Wheels, and are very close with pro trac's. They are of a two piece design, so you can paint them up real easy, and have the thick spoke that I think looks great on most early racers. here are some assembly shots showing them as they go together, and the last one is on a cut down wheel with period correct tire. I love them!
Image Hope this can be of use to ya'll
Re: Detailed wire wheel inserts for 1/25
Postby HomeRacingWorld » Mon Jul 16, 2018 5:24 am
That will do fine, thanks Bob
Postby TuscoTodd » Mon Jul 16, 2018 8:41 am
I like the way you utilize the original 1/8" axle hole for centering those - definitely makes for a great looking insert and is a great tip!
:text-bravo:
Postby waaytoomuchintothis » Thu Dec 20, 2018 12:23 am
Предоставленная информация очень полезна для меня.
The provided information is very useful to me?
Postby dw5555 » Thu Dec 20, 2018 6:23 am
dw5555
Postby HomeRacingWorld » Thu Dec 20, 2018 6:42 am
Spammer. They get through. Deleted. And time to change the sign up.
