Home Racing World • View topic - piranha motor wattage
Postby CrockettNZ » Mon Apr 04, 2016 10:44 pm
can anyone tell me what the wattage rating for the 21000 RPM piranha is
cheers
Dave
CrockettNZ
Re: piranha motor wattage
Postby Abarth Mike » Tue Apr 05, 2016 3:37 am
Says they are the same spec as slot.it orange in which case 9.8W @12v.
Abarth Mike
Postby McLiams » Tue Apr 05, 2016 4:35 am
Have tested the 6 on hand by (as closely as can be approximated) Mr. Livingston's method. They range from 7.86 w to 10.13 w, with an average of 8.95 w.
FWIW.
Mc
McLiams
Postby Brumos RSR » Tue Apr 05, 2016 7:49 am
Do you want high wattage or low wattage? Pardon my ignorance but what does it mean in motor terms? As I have only been looking at rpm and torque #s and picking motors based on sound.
Brumos RSR
Postby CrockettNZ » Tue Apr 05, 2016 12:57 pm
thanks guy's that fits into what I require
CrockettNZ
Postby CrockettNZ » Tue Apr 05, 2016 1:07 pm
CrockettNZ
Postby RichD » Wed Apr 06, 2016 6:27 am
Wattage is a measure of power and it is calculated from the motor's RPMs and torque measurments. Using horsepower units would result in rather small fractions, 1 HP = 746 watts, so when you are measuring small motors you at least end up with some numbers that are to the left of the decimal place. Two motors with the same watt rating could have very different RPMs and torque ratings, with different gears they could perform the same on the track.
Postby CrockettNZ » Wed Apr 06, 2016 2:32 pm
cheers for that info
that helps to make sense out of it all :text-thankyouyellow:
CrockettNZ
