Home Racing World • View topic - Policar compatible chassis how-to for March 761
Postby Conti_rowland » Thu Mar 31, 2016 2:50 pm
Conti_rowland
Re: Policar compatible chassis how-to for March 761
Postby chappy » Thu Mar 31, 2016 7:21 pm
Andi seeing as the Fly March and Fly Brabham use the same Fly chassis, is there a chance that your designed chassis will fit the Fly Brabham also.
Postby Conti_rowland » Thu Mar 31, 2016 11:04 pm
Hi Bob
Sadly not! If only life were that easy..... The Brabham's triangular form means that beyond the bottom plate the parts need to be different on the conversion. In fact I have some doubts whether I can do it due to the mounting position of the motor pod. I'm working on the Scalextric Mclaren M23 right now and will lookat the Brabham next.
Andi
Conti_rowland
Postby Rleog » Fri Apr 01, 2016 5:41 am
I have the McLaren M23 so I'll be waiting to see the Policar modifications. There will certainly be a delay before the Policar spare parts are readily available in the U.S.
Rleog
Postby chappy » Fri Apr 01, 2016 7:54 am
Thanks Andi, yes if only life were that simple.
I will definitely be looking forward to the Scaley M23, and perhaps its running mate ?
All the best
