mrrc motor replacement.
Postby seal666 » Thu Nov 12, 2015 8:56 am
While replacing the blown gear on my mrrc chapperal, somehow othe shaft on the motor got bent. Ok so it probably happened when I broke the wheel trying to tap it back on( need a smaller hammer). Anyway im having a hard time finding the mrrc replacement. I would like to do a like for like swap to keep the car copetitive with my 3 other mrrc cars. Failing that im considering using the mt1 slim line that has been recommended on these pages. Is this a snap in swap? Ive read Harrys articles, but am a little fearful of hot gluing a motor in and getting it misaligned. Replacing with a lower rpm motor will probably mean i need to reduce the mag force. I run scaley sport track
If i need to i will repower the other 3 cars so they are equal.Any and all advice is appreciated. If you have a spare motor for the sebring chassie, let me know
bob e
seal666
Re: mrrc motor replacement.
Postby TsgtRet » Thu Nov 12, 2015 9:54 am
You don't mention if you have the old "S" can chassis or the Sebring. I'm assuming that you have latter since you mention the MT/SL1 motor. This motor is an NC1 equivalent motor and would definitely be slower than your other 3 cars. You might also consider trying to find someone that has an MT/SL2 they want to part with (Mark no longer sells them), this would bring back up into the same ballpark as your other motors. Professor Motor lists a Scaleauto 20K FF motor (http://www.professormotor.com/product-p/sc-017.htm) that should fit and be in the neighborhood of your other MRRC motors. Hope this helps
Postby Florida_Slotter » Thu Nov 12, 2015 10:49 am
Electric Dreams carries the replacement motor for that MRRC.
I have found it to be the same speed of the original motor supplied in these cars.
Hope this helps.
