by Audi1 » Thu Apr 16, 2015 4:43 am
Thanks for the information, Mc. What type of instrument(s) are you using to measure the rpm of the motors? Is it a stroboscopic measurement (laser tach with reflective strip wheel on the motor)?
I ask because I have received a batch of H&R Hawk motors recently that were tested on a different type of instrument and they all measured greater than 18,000 rpm; one as high as 21,500 rpm. Torque measurements were also very close to spec on all motors tested. When I tested them, the 21.5k motor tested out at 17,500 rpm. So, it seems that the measuring system is key to determining if these motors reach spec, or not. Not a surprising outcome.
I have also received H&R Hawk motors from 4 different distributors and, using the testing apparatus that I have described, all of them show significant variability, with only one testing out at 17,500 rpm; the rest lower, some significantly lower.
I want to point out that if anyone is involved in racing where all of the cars are powered by the H&R Hawk motor, then this testing difference that we're picking up will be, virtually, inconsequential. However, if you're going to use the H&R Hawk in racing against other "18,000 rpm" motors, then having a motor that's below spec; in some cases significantly below spec, won't do you any favors on the race course; particularly if that course has long straights.
I would like to see H&R Racing respond to some of the messages that I've sent to them about the rpm performance of this motor, but so far, I haven't been able to hear back from them.
In closing, I realize that the use of the H&R Hawk is a choice; one among others that are available to me. So, I don't plan to spend anymore time describing this rpm issue. But, as I said in my original post, I like the H&R Hawk specs for racing in the 18,000 rpm motor class; particularly the torque. Who knows, perhaps its just the pretty blue color. ;)
Audi1 on Fri Apr 17, 2015 4:46 am, edited 1 time in total.
