Home Racing World • View topic - Guide Depth
Guide Depth
Guide Depth
Postby bookie » Tue Mar 03, 2015 3:38 pm
bookie
Re: Guide Depth
Postby Ky.Slot Racer » Tue Mar 03, 2015 3:45 pm
if i`m building a chassis from brass I design it so the braid holds the front wheels off the ground just enough to spin. Plastic chassis same, I shim or add the b nova to lower it. So for me as much as I can get into the groove without draging the bottom.
Ky.Slot Racer
HRW Master Modeler
Re: Guide Depth
Postby RichD » Wed Mar 04, 2015 7:15 am
If you race without magnets your cars will handle better if the front wheels are firmly planted at all times. The only exception to that might be if you are using a chassis with a very low center of gravity. You need to get the bottom of the guide flag blade as close to the bottom of the slot as possible. With a few cars you can add a spacer to get the guide deeper in the slot without lifting the front wheels off of the track. I use Slot.it wood track guides and trim them as needed. Those guides fit a lot of cars without having to modify the chassis.
Re: Guide Depth
Postby jcis4me » Tue Mar 10, 2015 9:12 am
Hey Rick
If you can sand down the fronts to lower the front end, is it possible to lower the front axle? Just a thought....
Marty
jcis4me
Re: Guide Depth
Postby HomeRacingWorld » Tue Mar 10, 2015 9:37 am
