by chappy » Fri Aug 29, 2014 12:52 pm
Bane, from what I understand, a drop of one tooth on the pinion is the same as an increas of 3 teeth on the spur. And an increase of 1 tooth is a decrease of 3 teeth on the spur. I may be out a bit on this but I think thats how, it works.
However if you are going from a 20 k motor to a 30 k motor, I would drive it before you change anything else.
Keep in mind that in this hobby as with most motor sports, you can have too much motor.
As a noob, you may not be familiar with rollout, so very quickly if using a 12 tooth pinion and 34 tooth spur, see in inches or mm how far your car moves for one comlete revolution of the motor.
Now if that motor is a 20 k, your gear ratio will tell, you how far it is capable, of travelling at max rpm.
Easy math now to figure how far it would travel at 30 k max rpm .
There are a lot of things that come into play with gears, such as ratio, but also gear diameter makes a difference to.
Just have some fun where you are and learn as you go along. Some folk have spent a lot of money on buying different motors and gears just to find it didnt give them the results they hoped for.
The guys at your club will be a good resource for you, so see what they are doing, most are willing to help a newcomer.
Regards
