Home Racing World • View topic - Which Wheels & PG Tires Fit a Ninco C1?
Postby Flytoo » Fri Jul 25, 2014 12:18 pm
I want to upgrade the wheels and tires. I'm thinking CBD 5 spoke classics,(I am open to other suggestions), but have no idea which ones would fit? What about PG tires? Which ones would be a good fit for the new wheels? I don't want anything sticking out past the fender wells. This is a parade lap car.
Flytoo
Re: Which Wheels & PG Tires Fit a Ninco C1?
Postby HomeRacingWorld » Fri Jul 25, 2014 12:25 pm
See new post for wheel/tire sizes.
Remember, you will need bushings, axle and crown as well.
Postby paul gage » Fri Jul 25, 2014 12:45 pm
what model are you doing? If it's a classic you might want to include a taller tire in your options...PGT-21105 or wider PGT-21125 are 1mm taller than the 20's. Have you looked at the new CB Design 14x8 Steelies. They are deep enough to take an insert too.
If you are doing a modern car that uses the larger OD wheels and you want somthiing narrower than the 20125, I also make a 20115, and 20105 for the 8mm wide wheels... ahh great, more decisions!
Slot Car Corner carries my full line in either PGT/XPG compounds... they can help you out too... oh ya! Pics when you're done please.
P
paul gage
Postby Flytoo » Fri Jul 25, 2014 10:41 pm
[img]IMG_0082[/img]
[img]IMG0083[/img]
[img]IMG0084[/img]
I hope these images work! Still struggling with posting pics.
Anyway, thank you Harry and Paul. I really appreciate all of the help. I'm pretty sure that this car is a Ninco Classic, but I know there are some folks here that can remove all doubt. Hopefully, someone will give us a hand. It has a pink NC-5 Speeder motor and it does say, made in Spain, on the chassis.
Harry, thanks for the reminder about bushings, axle and crown. I hadn't given any of that a thought. Do you know which ones I need to buy? I'm guessing SCC will have all of those goodies too?
Paul, if the above pics work, I should have no problem posting the "after photos" and will gladly do so. Thanks again!
I did contact SCC about this project, and they stated that they did not have a Ninco C1 in their stable, but would try to locate one to get the info for me. That's been a few days ago. I'm sure they're more than a little bit busy.
Flytoo
Postby Flytoo » Fri Jul 25, 2014 10:51 pm
Perhaps these might work?
Flytoo
Postby HomeRacingWorld » Sat Jul 26, 2014 3:24 am
Postby Flytoo » Sat Jul 26, 2014 5:10 am
Thank you for fixing, yet another one of my pics! I promise, I will learn how to post pics. :oops:
And, a huge,THANK YOU for all of the information, and that pic of the C1's.....oh my gosh, I'm still drooling.
Flytoo
Return to The Slot Car Garage
