bringing back a beat up monogram pin chassis
I picked this up used. I didn't even realize it was a pin type chassis. There was a plastic plate with a pin, and braid slots.
I cut the very front off, then soldered on a 1/8 tube, and a tongue to put a hole for a normal pivoting blade type guide.
The chassis will now be curt in half to allow wheelbase adjustment by putting piano wire in the 1/8 square tubes soldered down the inside corners.
The rear axle area was bent, and weak.
So I soldered decreasing diameter tubes across to reduce to a more modern 3/32 axle. Then I cut the center out for the crown gear.
not pretty, but should work
I'll hit it with the dremel to clean it up some before mounting to a body.\
blurry picture was the only ebay picture shown when I made the purchase
