bringing back a beat up monogram pin chassis
Bring Back Some Memories!
Postby williamg » Sat Apr 06, 2019 9:05 am
I picked this up used. I didn't even realize it was a pin type chassis. There was a plastic plate with a pin, and braid slots.
I cut the very front off, then soldered on a 1/8 tube, and a tongue to put a hole for a normal pivoting blade type guide.
The chassis will now be curt in half to allow wheelbase adjustment by putting piano wire in the 1/8 square tubes soldered down the inside corners.
The rear axle area was bent, and weak.
So I soldered decreasing diameter tubes across to reduce to a more modern 3/32 axle. Then I cut the center out for the crown gear.
not pretty, but should work
I'll hit it with the dremel to clean it up some before mounting to a body.\
blurry picture was the only ebay picture shown when I made the purchase
williamg
Re: bringing back a beat up monogram pin chassis
Postby chrisguyw » Sat Apr 06, 2019 12:25 pm
Hello Williamg........good to see you taking an interest in restoring some of the "olden goldies" :clap:
For what it is worth, I have restored/modified several of the older Monograms, and if there is anything in the following pics. that is of help,....... please use away !!.
All the early Monograms were somewhat flimsy at best and all really benefitted from "beefing up", not only in terms of handling, but, as you have discovered, in terms of strength,...as they did tend to Bend ;)
Two .055 rails have been soldered along the bottom of the chassis length.....this really helps not only with handling, but, strengthens some really weak parts of the chassis. On later versions I have run these rails to the front of the chassis plate.
A couple of .055 (.063 works just as well) "L" shaped bits of piano wire significantly beef up the rear uprights,.....and if you run the bottom rails (first pic.) all the way to the front of the chassis, the "U" shape bit on the front of the chassis is not needed.
A couple of "L's" strengthen the front uprights, and the downward legs of these "L's" can be trimmed to act as guide stops. (Your addition of a front axle tube does works equally well at strengthening the uprights)
The "newer" old Monograms had a removable motor mount, which was notoriously weak, and a piece of piano wire soldered here worked wonders........a piece of wire here on your chassis will help a lot !!
The biggest "Handling" tip on these old buggers was to cut/install a pan under the chassis to add weight/lower the cg.,......this one was cur from .063 brass, and mounts to the chassis with countersunk nuts/bolts.
A couple of shots of the finished rolling chassis.......the pan has been mounted with nuts/bolts, with urethane washers between the pan and the chassis plate to minimize vibrations.
Chris Walker
Enjoy your build :dance:.....and post your progress !! ...............they can be made to run very very well !!!
chrisguyw
Postby bill from nh » Sat Apr 06, 2019 2:11 pm
You wouldn't think so, but .055 piano wire is much easier to form & bend than .063. :)
bill from nh
Postby williamg » Sat Apr 06, 2019 2:46 pm
Wow, quite the job on that monogram chassis.
That model is my favorite type. I have some EJS repops. I agree, some extra eight is helpful in the handling department. ( http://www.ejshobbies.com/Monogram+slot+cars.html ) The ELDON repop is a bit stiffer, and seems to have fewer issues.
What did you do, sand that to get it looking so good?
I was thinking of maybe searching out a cheap tumbler.
This car here is a blast running the Stombecker version with some tabs soldered on for mounting.
williamg
Return to Vintage Slot Cars
