Brass chassis conversion for D Jag Strommie
Bring Back Some Memories!
Postby btaylor » Sun Sep 20, 2015 4:31 pm
Built up a simple brass chassis for the newest Strombecker member around here.
PM Motor bracket, 2mm brass rod, NC-1 motor, slot it 9x27 gears, and for the time being, some CBD 14x6 wheels with PG 21073 Tires. I added two posts to the body to mount the new brass chassis, and left the original chassis mounts intact. This car will retain the original finish and decals, with a coat of future to keep it all looking nice.
Great running little car! nice and smooth, with scale speed fun.ImageImageImage
Re: Brass chassis conversion for D Jag Strommie
Postby Gameover » Sun Sep 20, 2015 4:37 pm
Nice work bob!
Postby Florida_Slotter » Sun Sep 20, 2015 4:57 pm
Keep up the building.
Just a comment (remember, there is no wrong way) you could have put a piece of wire inside the frame tubing to join them. Your choice works, just saying there are other choices.
Thanks for building your car's chassis. Love to see this.
Postby HomeRacingWorld » Sun Sep 20, 2015 5:00 pm
Nice indeed Mr. Taylor sir!
Now I have some Carrera models I have thought about doing this same thing to. Not really vintage, but I'll race you when I finish.
Postby Nor Cal Mike » Sun Sep 20, 2015 6:03 pm
Well that didn't take very long! Nice job!
Postby dge467 » Sun Sep 20, 2015 6:21 pm
That is very slick! Nice work!
Postby TuscoTodd » Sun Sep 20, 2015 9:40 pm
NICE conversion sir! :D
Postby dreinecke » Sun Sep 20, 2015 10:32 pm
Perfect!
Postby Alaskaracer » Sun Sep 20, 2015 10:42 pm
Very nice!
Alaskaracer
Postby btaylor » Mon Sep 21, 2015 5:25 am
Thanks all! This turned out to be a great running little car. I was going to add some brass pans for weight, but with the heavy Strombecker body, it really didn't need any. So when the CB insert wheels get here, I will add the proper inserts, and it will be done.
And Marty, Thanks for the great idea on the chassis rails. On this one I used solid 2mm rod, so I couldn't put a wire inside the tubing to make the stretch. I had to go on the outside for that final wheelbase adjustment.
Postby chrisguyw » Mon Sep 21, 2015 7:34 pm
Nice job Bob!!
cheers
Chris Walker
chrisguyw
Return to Vintage Slot Cars
