Home Racing World • View topic - Spare set screws for old crown gears
Bring Back Some Memories!
Postby balsaworks » Sat Aug 16, 2014 3:07 am
I need set screws for the gears of some of my old slot cars; Atlas, Revell and Monogram.
Does anyone know the correct dimensions for these set screws and where to find spares?
balsaworks
Re: Spare set screws for old crown gears
Postby Ember » Sat Aug 16, 2014 4:48 am
You'll be able to get replacements from anyone that deals in small screws etc. It's merely a matter of knowing what size they are. How do they compare in size to the Slot.it ones, which are M2 or the NSR, which are M2.5? Of course, chances are they will be small gauge imperial sizes rather than metric.
Postby balsaworks » Sat Aug 16, 2014 10:36 am
Right - the thing is I'm not familiar with the imperial sizes. If someone could suggest what might the right size(s) I can get some screws to try out.
balsaworks
Postby filsautobody » Sat Aug 16, 2014 11:56 am
I have the same set up and gearing. Just pulled a screw and checked they are 2-56 NC. Don't know where you are located but if you need help getting them let me know.
filsautobody
Postby filsautobody » Sat Aug 16, 2014 11:58 am
Nice try Shotgun but 4-40 is toooooo large.
filsautobody
Postby balsaworks » Sat Aug 16, 2014 12:59 pm
balsaworks
Postby filsautobody » Sat Aug 16, 2014 1:45 pm
Hey Balsa,
N.C. = Numerical Control
Phil
filsautobody
Postby TuscoTodd » Sun Aug 17, 2014 5:45 am
On the screws there are two common designations, NC (or UNC) and NF (or UNF)
NC / UNC - Unified National Course
NF / UNF - Unified National Fine
I have never really thought about why they add the suffix since the threads per inch are listed - but I would guess it is just a quick ref.
Also for ref:
#4 screws - 40 threads per inch is NC, 48 threads per inch is NF
#2 screws - 56 threads per inch is NC, 64 threads per inch is the NF
Postby balsaworks » Wed Aug 27, 2014 1:40 pm
I purchased some set screws and thought I might as well get a selection of various sizes while I was at it. They're quite cheap, from several sources on the net. It turned out that the Atlas car that I started with required 2-56 screws as expected, but then chassis no. 2 needed 3-48. It may be that someone re-drilled and tapped that gear. In any case I'm now armed to tackle my fleet of vintage cars and that feels great!
balsaworks
Postby Ramcatlarry » Sun Apr 05, 2015 8:22 pm
Allen head socket set screws are SO MUCH easier to work with over the flat blade grubs found in some of the old gears. They were always available in the old days and I for one changed fasteners at my own will. The sizes were never as consistent as they are in modern parts.
Ramcatlarry
Return to Vintage Slot Cars
