Home Racing World • View topic - THE GLORY OF SCALEXTRIC!
Share Your Thoughts!
Postby Cosmic Bilby » Tue Dec 18, 2012 9:19 pm
G'day Guys,
Yep, as promised in another thread today, here is the GLORY OF SCALEXTRIC!
The "glory" of Scalextric is very simply this companies UTTER and ABSOLUTE domination of F1 class racing in 1/32 scale...
....It's true, no other manufacturer has seriously offered any significant opposition to Scalextric in the modern era.
Proslot? No, Ninco?, nope, SCX, a little if you turned a blind eye to their models outrageous track dimensions and the "Smokey Yunick" factor at work with their motors (Pro-Turbo plus motors WERE the swap way back). Carrera? ...I'll leave that to a bit later :)
For three of the four contenders mentioned you could pretty much say, "Thanks for coming, hope you brought a coat, its going to be cold when you wake up"! Scalextric F1's have been clinical in their domination of the 1/32 F1 class.
Naturally, Scaley being Scaley, there was always a little "fiddling" around the edges of the concept, and some models have more potential than others...
An example being the first release Williams and McLaren, most of us twigged early that the Williams was the bomb (Ahhh, and those "wet" tyres, they were sweet!). The McLaren had a little issue with the magnet pocket, it was fixable though if you had it nutted out.
Son Jake and I had a lot of success over the years with the Scalextric Toyota "Sport" F1 cars. With the amazing Mika Salo as one of the drivers featured in the release (he was brilliant, why didn't this beautiful Finn get the breaks lesser drivers appeared to), it was a no brainer for me. We had a few of these over the years, the two cars pictured are the last FC/SP club chassis we raced. They were stock, with the exception of Super Tire Yellow Dog slicks, they ran flat in the high four to flat five second lap range at club and 1.6-1.7 second laps on our home track, they were smooth and quick, we rarely were beaten.
Enter the current Scalextric FF motor era of their F1 releases...
....To be honest it had many of us stumped, Harry and I included. I can recall both of us having a chat and comparing notes about the new FF powered F1 Chassis. I had just written a review for SlotCar Outhouse featuring the new FF powered Renault (a lovely model in every way). Basically I had ripped just about every part off this thing trying to match the times set by the previous FC powered Renault release. It isn't a pretty picture seeing the angst of two slot car reviewers let me tell you!
Hence the reason why Jake and I stuck with FC powered cars for that long!
Anyway, as often happens, I started looking for that little bit more for our club cars, things were getting tighter in competition and we wanted to stay at the top of the heap.
...Enter the "walrus", this Williams was released alongside the FF powered Renault, I figured if I could tame it with a little "Smokey magic" /AKA cheating, it might be a good thing.
First thing to go was the stock rear rubber, it was replaced with Super Tires Yellow Dogs (PGT XPG's are just as good). Secondly, the stock "stepped" magnet was given the flick and replaced with a Slot.it. CN01 neo mag.
Finished model weight was 61 grams, nett downforce was a whopping 340Grams and motor speed from the stock FF motor was 14200RPM.
Wild!
Best lap was 1.5 seconds on our small four lane Scaley Sport home track.....
This was our second build, a 2004 Scalextric "Schumacher" Sport limited edition that we got from Bruce awhile back. The build was the same, nett downforce 360Grams, 14800RPM at the rear wheels. I don't know if Scalextric "grade" their FF motors and put the hot ones in the F1 cars, but this pair of FF's are wild, serious motive power!
The best we have ever got out of a stock Scaley FC motor after water dipping is 12200RPM from memory....
The Scaley Ferrari does 1.5 second laps as well on our home track but really shows its stuff on the club 18metre Ogilvy magna-braid layout, best lap there is 4.6 seconds, there is nothing in our club boxes that can match this, cheap performance for a tyre and magnet swap eh?
As alluded to earlier, there is one slot car maker that may just be able to be mentioned in the same breath as Scaley for F1 cars, that maker is CARRERA....
You see, a long time ago, I (as a fresh faced, non-jaded newbie) had the opportunity to put a (then) new Carrera F1 2002 Ferrari through its paces on our (then) much larger home layout.
What a revelation! Back then most of us accepted Carrera were a bit off the pace in comparison to many manufacturers at that time. This Carrera F1 offered performance very close to the earlier FC motored Scalextric F1 cars. IT WAS THAT GOOD!
On a large open layout, which our track was, the Carrera stock motor would run with the Scaley cars, it was quicker than Pro-Turbo SCX cars, the other two manufacturers didnt even rate a look in. About the only thing I can knock the Carrera for was the stock rubber, it was harder, therefore not as good getting the power down as either Scalextric or SCX (and stock rubber was what we used back then, IG's had only just come onto the market back then).
I wonder today if Carrera would be a match for Scalextric?
Anyway guys, the GLORY OF SCALEXTRIC is their efforts in F1 class, no other manufacturer, no matter how vaunted has dared pick up the "gauntlet" as yet...
...Maybe one day?
Cosmic Bilby
Not so fast....
Postby SuperSlab » Tue Dec 18, 2012 10:06 pm
While I like several of the Scaley F1 offerings, I consider Fly to be their appearance and non-magnet performance equal. My (marginally) fastest F1 is a Scaley Williams FW07 but my Fly March, Lotus 78 and Williams FW14 are right up there nipping at its (w)heels.
This is on an approximately 80 foot technical wood track. All the cars are just blueprinted with glued and trued urethane tyres: no lead, no nothing! And they are up in NSR lap time territory: SCREAMINGLY fast! And controlable enough that only my Scaley Raikonnen "2007" Ferrari has ever broken any parts (one side of the front wing) over many, many laps.
Some selected comparative lap times:
Scalextric Williams: 7.88 sec
Fly Williams: 7.943 sec
Fly Lotus 78: 7.997 sec
Scalextric Ferrari: 8.048 sec
Scalextric McLaren M23: 8.241 sec
Fly March 761: 8.202 sec
By no means a one horse race!
SuperSlab
Re: THE GLORY OF SCALEXTRIC!
Postby Cosmic Bilby » Wed Dec 19, 2012 1:36 am
...Yes!
I didn't consider Fly, I was looking at "modern era" F1, perhaps should've explained that a bit better but there you go :)
Fly make great F1 cars, no doubt about it, was good to see their offerings in the market for those who enjoy them....
As far as speed and very rapid lap times go, I reckon it would be hard to beat the Scaley F1 cars, they are a class act :)
Cosmic Bilby
Postby mrtiggz » Wed Dec 19, 2012 2:51 pm
here here! very much agree with you about scaley dominace in modern f1! but i do like the new scx f1 cars there very closely match now with there new power plants fitted to them. ive tried the carrera but just could keep up.
i race only 2009- upwards cars
mrtiggz
Postby Florida_Slotter » Wed Dec 19, 2012 2:57 pm
We recently started racing the Scalextric F1 cars at our club.
We're having a blast and everyone is having FUN!
Personally I love racing Formula 1 - open wheel racing requires a lot more driver control and creative passing skills.
Postby Cosmic Bilby » Wed Dec 19, 2012 4:28 pm
I will have to try the SCX models with that RK motor Mr Tiggz, the very little I've played about with them show they are extremely torquey!!!
Glad you guys like them Marty, they are the quickest 1/32 scale genre of slot car, very light, very fast creations, I love running them, the downside is that they are very, very fragile....
Cosmic Bilby
Postby goosenapper » Wed Dec 19, 2012 5:37 pm
goosenapper
Postby GTOking » Thu Dec 20, 2012 8:42 pm
After collecting a full field of Nascar and vintage Trans Am cars, I am starting to collect F1 cars. Santa is supposed to be bringing a Scaley 2011 Jenson Button McClaren and a Carrera 2011 Vettel Red Bull car. I can then do a comparison and decide which I will buy more of. I look forward to that, and then a new road course build to go with my oval. Thanks for the reviews of the F1. Fits right in to what my new interests are in slot cars.
GTOking
Postby Cosmic Bilby » Thu Dec 20, 2012 9:15 pm
No problems Sir!
I'm glad I could be of assistance :)
You will love them, they are different to the T/A cars and Nascars (which I enjoy too by the way), I think that is part of their appeal for me....
Cosmic Bilby
Return to Product Reviews!
