Home Racing World • View topic - SCALEXTRIC #C2401A FORD BOSS 302 MUSTANG #15
Share Your Thoughts!
Postby Cosmic Bilby » Fri Nov 30, 2012 6:48 am
By Rob Wessling
G’day Guys!
I've been reminiscing of late about all the milestones in our hobby over the last ten years or so. A lot of models have come and gone, some with barely a whisper, others stay firmly planted in the minds and hearts of many of us....
....I believe the models that started the boom in 1/32 scale Trans AM are one of the latter, namely the model I'd like to share in the way of a retro review here with my mates at HRW.
In 2002 I'd just come into the hobby, there were a lot of models to choose from around this time but unfortunately for some of us most were of prototypes of cars from Europe. Fine if that was your scene, but for myself (and a lot of others too it seems) I really wanted some classic American gear.
As things turned out, Scalextric came to the party in 2002 with two limited edition T/A cars, the 1969 Ford Boss 302 Mustang and a 1969 Chev Camaro Z28. Both models came in the two (historical) liveries apiece for their respective teams, wow I was stoked!!! I bought a #16 Follmer Mustang and a Penske Sunoco Camaro, these were my third and fourth models, my first two were a pair of Cadillac's that came with a Sport set I used as a base for my layout. Believe it or not the Scaley T/A models were in very high demand, I wanted to collect the four liveries but they sold out very quickly from dealers everywhere, Scalextric had hit a home run....
Man did these two T/A cars cop a hiding! They were used almost non-stop by my kids (and of course me!), we loved them, over time we bought more, even holding race meets on our home layout with other racers that had these cars, as far as I know scale Trans Am racing is still alive and kicking.
Naturally nothing is never perfect, and these models were not perfect! They copped a lot of flak about scale issues, and really that was fair comment, BUT we knew what they were meant to represent and many of us felt Scalextric could be forgiven for being a bit "liberal" in this department....
....EXCEPT for the infamous MR. BLOBBY HEAD!!! 'Strewth, what was the design team thinking when they came out with this drivers figure??? Man, if ever there was a candidate for a "bag job" this "guy" had to be it :) Nevertheless we accepted this small "setback" with grace and continued on racing and loving these cars...
The Scalextric Trans AM cars were very quick back then, in fact one of the quickest stock magnet cars you could buy. I thought it would be interesting to re-visit the Scaley T/A cars ten years on to see how they go with modern tuning techniques and tyres. In this review I will be keeping the Scaley Mustang essentially stock, the only non-Stock item I will use are a set of PGT XPG tyres, Paul makes excellent rubber, I think this model deserves it!
As mentioned, the model on test is a new in box Scalextric 1969 Boss 302 Mustang #15, driven by the famous Parnelli Jones. This is a "Sport" limited edition, basically the same as any of the myriad liveries of the Scaley Mustangs with the exception of having metal bearings for the rear axle to run in. I'm not going to go into an indepth on the chassis layout, I'm certain you will all know this chassis very well....
In stock out of the box condition this particular model ran a best of 2.2 seconds on my small four lane Scalextric Sport layout. I would consider this a pretty good time for a dead stock slot car, it hooked up reasonably well, even on ten year old standard rubber! It felt like many other Scaley Mustangs I've had over the years, lots of magnet, stable, fast and such an awful lot of fun :)
...And it sounded great too, nothing beats a sidewinder configuration for sound as it comes up to peak revs, very nice indeed!
After its SOOB run I thought I'd get some figures as a baseline, this particular model yielded 226 grams (net) of downforce on my magnet marshall with the stock Scaley mag in its standard location. These "Sport" releases also came with a small round mag that could be placed in a pocket near the front axle, I would really recommend NOT using the extra mag, it really loads up the motor, anything over 200 grams net downforce is plenty for a model that weighs in at 82 grams (this models weight)....
The motor in this model managed 10800RPM at the rear wheels, which is about average for a Scalextric Mabuchi. Of course the motor in this model is packaged as a "Sport" motor, the shiny silver wrapper is eyecatching indeed but remove the label and you will find its just another "Black Stripe" Scaley FC motor, nothing like a bit of hype is there???
OK, with the preliminaries out of the way it was time to get this bad boy stripped down and trued up, I felt confident that we would be able to see a small improvement in on-track performance.
First job was truing up the rear wheels, ditching the stock rubber and mounting a set of PGT XPG's, I'm pleased to report that the bearing to axle fit was first rate, as was the rim concentricity, obviously Scalextric was on the money ten years ago and full credit to them!
The PGT's fitted up no problems, they were superglued, trued to 20.45mm and had the edges rounded for both scale appearance and to assist cornering. The rear end was then re-assembled, spur gear "check glued" with CA glue as were the axle bearings when re-fitted to the chassis.
Next the motor was water dipped, cleaned, dried and oiled and re-fitted to the chassis. I did not use CA glue to glue it to the chassis, I decided to run a small bead of hot glue along the bottom edge of the front of the motor, this bead also keeps the magnet seated. I have had the magnet come loose occasionally during racing, this is usually in conjunction with the model its attached to deciding it wants to try flying.... :)
....Moving forward along the chassis I trued up the front rims, re-mounted the stock rubber, trued both tyres to 18.5mm, cut the shoulders and capped them with CA glue. Again, congrats to Mr Scalextric for providing nice concentric wheels to work with.
Finally we come to what is probably the Achilles heel of this era Scalextric model, the guide assembly, actually come to think of it, this is pretty endemic for many manufacturers still today isn't it?
Anyway, as you can see from the photo, this model has one of those ugly self-centering style guides with a clip in blade. No great drama really, what needs to be done is to remove the plastic cross-brace (held by two screws) and also that spring you can see under it....
Next, the guide (blue) is removed and the back end of the blade ground down so it is in line with the triangle/trapezoid shaped main "body" of the guide. This is done to help the guide get through tighter radius corners without binding. Naturally this would be an opportune time to give the braids the once over (it is very nice braid too, I re-braid most of my models with this braid). About the only thing I do a little differently here is turn the short "tail" of the braid thats been tucked in under the main part backwards, this helps the front end sit that tiny bit lower....
Finally on the underside of where the guide clips in there are two silver pick ups that run along the braid that sits on top of the guide. It pays to spend a few minutes test fitting these and bending the pickups so they run smoothly over the braid and give a little tension to the guide as it turns laterally. I know most of us are aware of these old tuning tips, but maybe, just maybe a newer slot racer may pick up one of these cars off the net and want to use it :)
OK, with tuning out of the way it was time to give the Scaley Boss Mustang a run, which I did and I'm pleased to advise my tinkering paid off with a best lap of 1.9 seconds! It ran very nicely, smooth, grippy, with the typical magnet chassis outcome when pushed too hard, no warning, no oversteer, just a total loss of grip and off it would spear. JUST WHAT I'M USED TO!!!! I loved it, beautiful, fast consistent laps, as I remember, these Scaley Mustangs just hang on to the bitter end, no noticeable top heavy feel to them, the ideal magnet racer for sure.
...And the car looked great too, an iconic livery from a golden era of racing, what more could we ask for!!!
Sadly this story doesn't end 100% positively for the Scalextric '69 Boss 302 Mustang from 2002...
...It was the "king" of 1/32 scale T/A racing back then (no Scaley Camaro I've ever had could match the Mustangs), but unfortunately there is a newer, faster offering from another manufacturer on the shelves in 2012. No, not SCX, the Cuda's can't touch this Scaley on my layout or our local clubs magnabraid Ogilvy track, the PIONEER Notchback Mustangs can however. I recently built a 1967 Pioneer Mustang using the same procedures mentioned in this review, its best on our layout is 1.8 seconds! It flies, the motor is superior too, more punch off the corners, I'm certain the Pioneer T/A would prevail on larger track as well.
From an aesthetic viewpoint the Pioneer is better as well, great detail, excellent in fact.
So where does that leave our review car?
I'd say it leaves it as one of the most iconic plastic chassis models of our era! The Scalextric T/A cars were the start of something really good for us, without them it may have left those of us that love US cars out in left field for many years....
....Its still an excellent model, the livery and model year of the prototype are awesome (Freudian slip), as demonstrated whether out of the box standard or tuned, this model still hauls the mail with the best of them.
I still love this model, its a part of my past, my son Jake and I will be able to continue our on-track skirmishes for many years to come with both the #15 car and our rejuvenated original #16 car (yep it still survives, albeit with a replacement motor and yellowdogs on the tail-end, 2.0 laps are still pretty good for this old hammer!).....
Thanks Guys!!!
Cosmic Bilby
Re: SCALEXTRIC #C2401A FORD BOSS 302 MUSTANG #15
Postby HomeRacingWorld » Fri Nov 30, 2012 8:55 am
Nice trip back in time "mate" (notice my accent is getting better?)
I was just talking about these models with Cheater. Scaley hit a home run then and what great times we have had with them over the years.
Postby dreinecke » Fri Nov 30, 2012 9:03 am
Postby Scatman1 » Fri Nov 30, 2012 9:19 am
Great article. Now get busy on the Caddy one. ;) The black Motorola was sweet looking. I still have both and will keep them for a long time.
Scatman1
Postby Cosmic Bilby » Fri Nov 30, 2012 6:13 pm
Thanks H, David and Tony :)
They were a good thing, just reviewing the Mustang yesterday brought on a lot of really cool memories, my family, indoctrination into the cult that is HRW :)
All good things, and I got a really excellent runner out of it as well....
Its a shame these cars are sitting on shelves all over the globe in their boxes not being used!
The great thing about the GFC (about the only good thing actually) is that collector prices have plummeted and these older cars are becoming affordable again.
I made the personal decision recently to start raiding my "collection" for cars that I had a genuine desire to run, its been a wise move I think. It gives me huge enjoyment to tune and run them, far more than seeing them stacked up on shelves....
Anyway, Tony, I may do a write up on those Scaley Caddy's at a later date! I know one of mine got a bit of a touch up with a re-gear, an independent front end and a bit of body lightening, but I think the other is essentially stock and low use. At the time ours were pretty much forgotten and relegated the shelf, we liked cars with more magnet (Fly stuff was pretty quick then too!).
Thanks for your comment guys, much appreciated!
Cosmic Bilby
Postby goosenapper » Fri Nov 30, 2012 6:42 pm
Good review, but even better photos! Everything looks crisp and clear. Thanks for posting this. :clap:
goosenapper
Postby Cosmic Bilby » Fri Nov 30, 2012 8:22 pm
Thank you Goosesnapper!!!
My wife actually did the photos, I think she went well too just quietly :)
We bought a new Nikon a little while ago and are still trying to work out the close-up stuff (my efforts quite frankly sucked, H has my back though, he is ready to assist if we can't make sense of it)....
Its a neat camera, our last one was a Fuji, H had one as well some years back, ours has a lens like the bottom of a coke bottle, hence the switch to the Nikon.
A bit of practice will help get things sorted out though I expect :)
Cosmic Bilby
Postby ListerStormGT » Fri Nov 30, 2012 10:16 pm
Great write up, these are still a great looking car one of my favorites. Thanks for the trip back in time. 8-)
Postby Cosmic Bilby » Sat Dec 01, 2012 5:57 am
That is a pity RM,
The '70 Boss looks so nice with that grille and yellow as well, wow! (I've seen that livery and wouldn't mind it).
As David pointed out earlier in the thread, there are duds (his Smokey Yunick car being a case in point).
There are duds in all makes, I have seen my share of them over the years as we all have.
No, they aren't a "race car", thats true, they are a scale model, as are the majority of models in 1/32, the only models I consider true race cars are the likes of NSR, SLot.it., Sloting Plus and the rest.
But many of us like running and racing "scale models", the Trans AM series of models from the three manufacturers (Scalextric, Pioneer and SCX) make for an excellent series.
I can see where you are at with this car of yours, the Scaley T/A cars run pretty well generally out of the box, which is essentially what the class was at your club, is that right?
The mods (with the exception of the rear aftermarket tyres) I made to the review car is pretty much how many of us would set a chassis up for "stock" class some years back. Glue and true everything, yes the guide is "weird" but you can make them pretty good if you lose the centering spring and fiddle with the pick-up prongs and shave the guide a bit as I outlined. About the only thing I ever remember having trouble with was the guide popping out when they got a bit of wear on them....
....I like the braid, as I said I use it on everything (even my SCX cars :) ), it works well for me on Sport and magnabraid, and yes it does wear, I really hate changing braids :)
If you are limited to stock rear rubber you can do a couple of things besides truing and gluing. When we used stock rear rubber we used to take a small scuff pad of sandpaper and give the tyres a quick spin before a heat to rough them up a bit, then we would tape off with electrical or gaffa tape. It worked and I imagine it still would.
The other thing you can do with stock rubber is treat it with NSR tyre conditioning oil. Its good stuff, works well, but I always found it really messy and was glad to make the change to urethane tyres.
If you run magnet at your club invest in a Magnet Marshall, all magnets aren't equal and a MM really makes a difference. This is the same for motors, water dipping etc isn't worth a pinch of the proverbial unless you can measure motor performance in a quantitative manner, a cheap motor checker helps you weed out the duds and lets you use the strongest motor for the job.
As far as T/A class cars go, I would choose a Pioneer Mustang over the Scaley, the Pioneer car is the superior chassis, providing it can hack the rough stuff at club comps, Scaley T/A cars do, they are pretty solid things.
I love my SCX Cudas, but honestly, even with "Smokey yunick" fiddling the motors, the other two brands are better options....
Maybe we can get a thread going in the 1/32 part of the forum regarding tuning for Scaley cars? There is a world of knowledge amongst the guys on this stuff :)
Cosmic Bilby
Postby Fred Fries » Sat Dec 01, 2012 6:25 am
RM, if you want to shim the axle and keep stock wheels, take your feeler gage and determine how much shim/washer you need in there, then remove entire axle assembly, move the bushing over to give some working room, If you can come up with nylon washers the correct width, or thin enough metal ones, you can snip a slot thru to center hole and slip them over the axle without ever removing the knurled on wheels, then just replace assy.
Fred
Fred Fries
Postby Cosmic Bilby » Sun Dec 16, 2012 5:11 am
Hey RM,
If your club rules allow it ditch the rear rubber and go urethane....
....If you have to use the stock rubber, sand it down, profile a nice "shoulder" into the sidewall and hit them up with NSR brand rubber conditioning oil.
Be liberal in its application, leave it sit for a week or so, use shellite to wipe off the residual before using it.
As an added sneak, just before you race give the rears (treated as above) a good rub on fresh gaffa tape. You can nearly get as good lap times this way as with urethane aftermarket tyres.
Lots of stuffing around (and mess though), I decided to cheat myself and use urethanes, saved me a heap of time :)
Cosmic Bilby
Postby Cosmic Bilby » Sun Dec 16, 2012 5:29 am
Ok,
I'd trust his opinion for sure, he has been doing slots a long, long time!
I'll have to get some and try it for myself :)
Cosmic Bilby
Return to Product Reviews!
