Home Racing World • View topic - Carrera Evolution 65 mustang
Share Your Thoughts!
Postby death on 4 wheels » Sun Aug 02, 2015 7:24 am
I recently got these. Is there anyone who has aftermarket rims and tires? Or does anyone know what rims and tires are compatible? MMainly for the mustang.
death on 4 wheels
Re: Carrera Evolution 65 mustang
Postby dw5555 » Sun Aug 02, 2015 7:58 am
Carrera's axles are knurled with the wheel pressed on. In a lot of cases you can pull the wheel off without breaking it but then your still stuck with axles that won't accept another wheel unless you somehow grind down the knurling. It's easier to replace the axle with the std 3/32 axle and use aluminum wheels. Paul Gage makes tires for both cars with the factory wheels.
Carrera made several different styles of wheels for the Mustang. (GT350 for one) The wheels come mounted on the axle so you can just swap out the whole assy. IF they are available you can just order them from a dealer. (Hardly anyone stocks axle sets)
Dave
dw5555
Postby waaytoomuchintothis » Sun Aug 02, 2015 8:21 am
But you can usually find them online.
Postby HomeRacingWorld » Sun Aug 02, 2015 8:29 am
Postby TsgtRet » Sun Aug 02, 2015 8:47 am
LEB Hobbies stocks quite a few of the "stock" Carrera axle sets (https://www.lebhobbies.com/carrera-132- ... 54147f85e6 ). The most important consideration is whether the car has the earlier E100 or later E200 motor set up.
Hope this helps.
Postby RazorJon » Sun Aug 02, 2015 12:00 pm
I am pretty sure both those cars have the same tires, those older Carrera wheels true up fine unless one is really bent, I would just true the wheels and replace the tires with PG's and have fun with those 2 bad boys, those cars run great
Postby death on 4 wheels » Sun Aug 02, 2015 4:08 pm
Okay can I put a axle assembly from say a 67 mustang in my 65. Or even a 2014 mustang. Are all Mustang axle assemblies interchangeable?
death on 4 wheels
Postby RazorJon » Sun Aug 02, 2015 4:13 pm
Postby dw5555 » Mon Aug 03, 2015 7:41 am
I have the 67 Mustang and it's 1 7/8" center of the wheel to center of wheel. Sorry don't have the 65..
Dave
dw5555
Return to Product Reviews!
