Home Racing World • View topic - 62 Impala
62 Impala
Vintage to Modern
62 Impala
Postby DixonJohn » Sun Aug 03, 2014 3:12 pm
DixonJohn
"The Mayor"
Re: 62 Impala
Postby DixonJohn » Sun Aug 03, 2014 3:14 pm
Almost forgot, It is a nail polish finish. The phone camera dosen't show the shine of the clear, bur it is there
DixonJohn
"The Mayor"
Re: 62 Impala
Postby HomeRacingWorld » Sun Aug 03, 2014 3:25 pm
Not bad at all!!!
Re: 62 Impala
Postby DixonJohn » Sun Aug 03, 2014 3:33 pm
Custom wood grained tech block. Thats what your talking about , right??? I should have a few of those for ya when I get home. The make good display stands
DixonJohn
"The Mayor"
Re: 62 Impala
Postby TuscoTodd » Sun Aug 03, 2014 3:38 pm
I have GOT to try that nail polish base trick! That looks sweet! :D
Re: 62 Impala
Postby DixonJohn » Sun Aug 03, 2014 4:00 pm
so far I have found that mixing it around 50/50 or so seems to work pretty well. It can be mixed with any type laquer thinner. Right now I'm using some thinner from work. It seems to do better than using the Sunnydale brand I use to use. Something else I have found is experiment with different air settings and distance you spraying from the car. I'm spraying with a single action Pasache H series airbrush. The .5 tip does pretty good as long as the flakes and pearls aren't great big.
I plan on modifying a tip and air cap to see if it will spray some of the bigger flakes and pearls. I'll let you all know
DixonJohn
"The Mayor"
Re: 62 Impala
Postby dreinecke » Sun Aug 03, 2014 4:05 pm
Good looking Imp!
Re: 62 Impala
Postby TuscoTodd » Sun Aug 03, 2014 5:00 pm
Re: 62 Impala
Postby OldDogMotorsports » Sun Aug 03, 2014 7:27 pm
nice ol bubbletop!
OldDogMotorsports
Re: 62 Impala
Postby dge467 » Sun Aug 03, 2014 8:35 pm
Very nice!
Return to Holeshot Alley!
