ADJUSTABLE WHEELIE BARS
Mon Dec 10, 2012 11:32 am
by gonegonzo
I'm looking for Adjustable Wheelie Bars for my 1/24th drag cars .
Thx
Gonzo
Re: ADJUSTABLE WHEELIE BARS
Fri Dec 28, 2012 4:38 pm
by BIG E
Can't believe nobody's tried to help you yet! It's not my main slot thing, but I do have a few 1/24 drag cars that I race every so often. My friends who are really serious about 1/24 drag stuff usually make the wheelie bars out of 1/16" piano wire (steel rod). A few inches long, a 1/16" axle across the back with a pair of aluminum wheels and O-ring tires (they look like high tech HO fronts) mounted is about it. I see them adjusting the height on a set up block with a soldering iron on the 'wheelie' axle.
Someone else out there has got to have the proper specs to help this guy out. How about it, fellow racers? I know there are lots of you "55 footers" out there in cyberspace.
Hope I've helped a little. Happy New Year... Ernie
Sun Dec 30, 2012 6:18 pm
by 4424ever
Hey Gonzo what chassis are you using ?. Anything I've seen on the market have the wheelie bar adjustment desigened in and are adjusted by soldering the axle at your preffered hight.
Wed Jan 02, 2013 6:10 am
by Slot-Rev
Gonzo,What chassis are you using? I have a couple different designs I have used.
Wed Jan 02, 2013 10:42 pm
by gonegonzo
I build my own frames out of Piano wire .
I'm trying to keep away from the soldering adjustment and shooting for a mechanical one .
Thx
Gonzo
