Home Racing World • View topic - 1/32 mods
1/32 mods
1/32 mods
Postby strangebrew » Sat Jan 24, 2015 5:56 pm
strangebrew
Re: 1/32 mods
Postby RazorJon » Sat Jan 24, 2015 6:50 pm
those are awesome, can we see more of the Chassis :text-thankyouyellow:
Re: 1/32 mods
Postby HomeRacingWorld » Sat Jan 24, 2015 7:07 pm
here we go again boys :)
Re: 1/32 mods
Postby btaylor » Sat Jan 24, 2015 7:41 pm
Im in!
Nice rides strangebrew!
Re: 1/32 mods
Postby slotguy » Sun Jan 25, 2015 10:50 am
Nice mods ....where did you get the bodies from would like to get some also what wheels and tire set up . You should do a thred on the build info
Tony
slotguy
slotguy
Re: 1/32 mods
Postby strangebrew » Sun Jan 25, 2015 5:02 pm
I'm just experimenting with bodies right now & using the chassis for set up.
The coupe is a 1:32 Pyro that I hade to widen to get "in scale". I have no way to get the fenders "scale" so it had to be a modified.
I cast the sedan from a 1:32 die cast car. I'm not very good at this, so I only get 1 out of 3 that are any good.
I took one of the worst & chopped it up to become what you see.
My plan is to rough out some other types of modified bodies & set them up on that chassis.
The modified wheels I cast from a combination of M&T inserts, Pro Track wheels, brass & styrene tube.
The tires I formed using a couple sizes of PVC pipe glued inside each other & turned on a yard sale jeweler's lathe then molded &
cast in urethane.
I'm planning a 50 Chevy, 49 Ford & maybe a 63 Falcon modified bodies to post here. I'd like to find a Pinto, Nash Metropolitan, Vega, Corvair
& Willys coupe to cut up.
I've got a 40 Ford coupe floating somewhere in the P-Bop. Also got an early Mustang & Camaro to do also.
That's what ran in my neighborhood in the 70's.
strangebrew
Re: 1/32 mods
Postby HomeRacingWorld » Mon Jan 26, 2015 11:16 am
Mr. Brew, let me know when you can make it down again please. I have Jalopy bodies and ordering a Vega. Might as jump in with both feet :)
Alos have a new NYMod coming I showed you.
Re: 1/32 mods
Postby strangebrew » Mon Jan 26, 2015 11:30 am
OK Gotta' put somthin' together to bring 1st.
strangebrew
Re: 1/32 mods
Postby strangebrew » Tue Jan 27, 2015 4:41 pm
strangebrew
Re: 1/32 mods
Postby HomeRacingWorld » Tue Jan 27, 2015 5:12 pm
Man that looks good. Thank you for the humpbacks too, just got them in.
We are gonna be busy around here.
Re: 1/32 mods
Postby strangebrew » Tue Jan 27, 2015 6:06 pm
strangebrew
Re: 1/32 mods
Postby HomeRacingWorld » Tue Jan 27, 2015 6:32 pm
Hey, that is Sellers in the Flying duece right?
Re: 1/32 mods
Postby strangebrew » Tue Jan 27, 2015 9:13 pm
Yup.....I think he drove the blue #2 also when
Eddie Petroff threw a bunch of money at him to drive.
strangebrew
