Home Racing World • View topic - 1/24 scale stocker
1/24 scale stocker
1/24 scale stocker
Postby woodman » Sun Dec 27, 2015 12:45 pm
Starting with a steel womp chassis cut in half and lengthened the wheel base to 4 1/2" ......
Some guys attach these hard body's with pins, Im trying the same.....
woodman
Re: 1/24 scale stocker
Postby woodman » Sun Dec 27, 2015 12:49 pm
57 Fords, luve um......
woodman
Postby HomeRacingWorld » Sun Dec 27, 2015 2:19 pm
Nice bumpers.
Postby DRW21 » Sun Dec 27, 2015 4:10 pm
Looks great!!!!!!
I like the way you have kept to the factory shape for the bumpers - very cool and keep those pix coming - awesome.
DRW21
Postby nhdungeonracer » Sun Dec 27, 2015 4:24 pm
That does look good!! Nice work! :auto-checkeredflag:
Postby woodman » Thu Dec 31, 2015 3:04 pm
Need to decal and clear coat......
A 63 1/2 galaxy fastback 500 awates. .....
woodman
Postby Vintage 1/24 » Thu Dec 31, 2015 6:06 pm
I like those Big Fords!
We run a 'street stock' class locally that is very similar, based one the 'one-cut' Womp and 1/25 scale model kits...
Vintage 1/24
Mr. NY Modified
Postby woodman » Wed Jan 06, 2016 11:29 am
Another 57......
woodman
Postby RazorJon » Wed Jan 06, 2016 12:09 pm
very nice builds sir :text-bravo:
Postby RazorJon » Wed Jan 06, 2016 12:10 pm
PM sent
Postby BIG E » Wed Jan 06, 2016 6:45 pm
Very nice builds, I especially like the '57 FORD. We used to employ the pin/tube mounting method back in the early 1980's running in commercial track series. After busting out the plastic on the rocker panels repeatedly, we switched to Velrco. All that was needed was a 1/4" wide piece of thin flat brass soldered to each side of the chassis, somewhere between 2-3" long, depending on the wheelbase. The Velcro allows the body to move and absorb much of the shock from collisions, whether they be with other cars or the wall. We typically run at speeds of up to 50 actual MPH on the commercial tracks with stock Parma Deathstar 16D motors, and with the cars weighing in at 175-200 grams, that really packs a wallop during some of the wrecks!
Another advantage of using the Velcro is not having to line up those four pins and tubes on each car, and it allows for for the body to be adjusted just a bit front to back or up and down during pit stops between heats. Quick swaps of a body from one chassis to another are possible, too, as we usually put the Velcro's "soft" side on the body for just that reason, the "hard" side seems to hold up better on the chassis, anyway. With many of the hard body racers at commercial tracks now using the Parma FCR 4" or 4 1/2" chassis, the interchangeability factor is even greater. We'll run a 10 week season with NASCAR "Cup" bodies (we've had a series with the truck bodies, too), switch to Musclecar bodies the next, Jalopies ('49-'57 American cars), Vintage Trans Am, single make Corvette or Ford GT spec races, ect., by just swapping the body and maybe adjusting the lead in the chassis a bit. My personal favorite class is the '58-'72 American intermediate and full size street car bodies with radiused wheel wells and 3 1/4" maximum track width (this can of course be tucked in to 3" on smaller tracks with tighter lane spacing). Also, these cars are required to run the stock plastic kit bumpers, no metal chassis mounted crash bars are permitted in these series.
I've still got some of my old stretched Womp chassis builds, both road race and oval track cars, and enjoy giving them a run every once in a while just for fun! Of course, at the lower speeds run on home and club tracks these type of chassis are just fine for competition, as you very well know, I'm sure! Some cool cars you've got in your stable, have fun building more and racing them!
Thanks for the photos... ENJOY!! -- Ernie :>)
BIG E
Postby bill from nh » Fri Jan 08, 2016 9:15 pm
Steve, have you ever used a Parma brass womp to build these 1/24 scale stockers? I realize they're a bit heavier & more expensive than the steel womps.
bill from nh
Postby woodman » Sat Jan 09, 2016 10:43 am
Good info big e, the chevy is velcro and much quieter and seems smother......
I have not used the brass chassis......
woodman
Postby mattb » Sat Jan 09, 2016 1:13 pm
P1010003.JPGP1010002.JPGHere is the 57 I just finished up. It is built to the rules for the "fairground stocker" class at the local raceway. I don't organize race, but the cars my group builds are all setup like this car, but bodies vary. I wanted a "stocker" that was different and easy to spot, so I pulled this old body out and came up with this scheme.
All our cars use H&R chassis, MT5 motors, pro track 1/2 foam for stockers and geared 3-1. Some guys like 90's style Nascar, I like the 60's stuff, one guy likes Superbird and we have a General Lee and a Back to the Future car.
We all strive for real equal performance and just have fun!
Postby woodman » Sun Jan 10, 2016 1:58 pm
Good one matt....
woodman
