what controllers
what controllers
Postby slotguy » Thu Feb 19, 2015 5:51 am
Hey guys..well now that I am building all these 1/32 cars I need a track to run them on . Going to build a small bullring to race on. A 12 x 4 with 3 lanes and 3.5 lane spacing and 12 volt battery power.plan on using a h&r 18.000 rpm motor in the cars what controller do I use from these type of motors a low ohm like a 2 or ohm or should I go to more like this 25 ohm . I think the lower ohm will cause the car to react to fast on this short track .could use some input from you guys
Thanks
Tony
slotguy
Re: what controllers
Postby HomeRacingWorld » Thu Feb 19, 2015 6:15 am
Correct. You would enjoy a 25. That's the ones we had on our oval for many years. Worked fine.
Postby HomeRacingWorld » Thu Feb 19, 2015 6:16 am
Postby BIG E » Thu Feb 19, 2015 1:21 pm
C'mon, Tony -- you've got the guy with a bag of different value controllers right in your racing program -- we'll talk Monday night, call me before then.
This should be easy -- Ernie :>)
BIG E
