Home Racing World • View topic - From the Strangebrew Coachworks
Re: From the Strangebrew Coachworks
Postby strangebrew » Thu Aug 20, 2015 7:01 pm
Guess nobody can beat me that way huh?
strangebrew
Postby Gameover » Thu Aug 20, 2015 8:10 pm
Another great car brew!!!! Im working up to build another chassis like the one you sent. I just picked up some brass rod to do it. Now just need the time and mostly the patience you have! :)
Postby dreinecke » Fri Aug 21, 2015 9:34 pm
That is simply awesome looking!!! Excellent work as always!
Postby TuscoTodd » Sat Aug 22, 2015 9:39 am
That is one SWEET looking machine!
Two thumbs up sir!
Postby strangebrew » Sat Aug 22, 2015 9:58 am
The lighter coupe looks to be faster than any of the brass cars so far....same motor, gear ratio, wheelbase/track, tire size etc.
It needs the dropped guide in order to keep contact, since it's quite a bit lighter than the brass & picks the front a bit
& I didn't want to add weight, which defeats the purpose of a lighter car!!
(I stuck the guide arm to the frame with a bit of silicone to make it solid in order to do a comparison)
Since both the styrene chassis' I've done are hack jobs....I think I'll build a new one from scratch
designed as 1/32 from the start, & if I like it I may try to resin cast it. I've got a '37 Chevy coupe body that needs a chassis.
My dirt tires want to chatter when you're hard in the corner which is why I thought a lighter car would help eliminate that
& it does....(almost) The tires actually wear off most of the tread after 300 or 400 laps on my short track (15 minutes or so)
(I guess it's the tread pattern that gives too much side bite) I've got some harder Urethane that I haven't
opened up yet, so I think I'll cast some harder tires for the heavier cars & see what happens.......................
Curious to see what happens at Harry's????
This is the funnnn part of slots for me, trying to think "outside the box" & try something different.
Failure is 75% of the learning process.
strangebrew
Postby strangebrew » Sat Aug 22, 2015 11:05 am
strangebrew
Postby strangebrew » Sat Aug 29, 2015 2:24 pm
strangebrew
Postby HomeRacingWorld » Sat Aug 29, 2015 3:57 pm
Allright, this is going to be great.
I have a special car in from the Coachworks...what a stunner. Will post pics soon.
Postby TuscoTodd » Sun Aug 30, 2015 8:18 am
Looks like another awesome build in the works!
:text-bravo:
Postby strangebrew » Wed Sep 02, 2015 7:16 pm
strangebrew
Postby HomeRacingWorld » Wed Sep 02, 2015 7:42 pm
Holy Shaggin' Wagons Batman!
If you cast it, I'll put my pre-pre order in now.
What a great car. You really have one heck of a style and I like it :)
Postby dreinecke » Wed Sep 02, 2015 8:19 pm
That is awesome!!!
Postby Gameover » Wed Sep 02, 2015 9:21 pm
That thing is neat as crap!
Postby chappy » Wed Sep 02, 2015 11:19 pm
Brew I see you are using the Reoflex urethane 40 shore , and going to, try the 50 shore.
I have used the Vitaflex urethane, same manufacturer and found it lasts a bit longer.
perhaps a bit more durable is the right word.
Also if you mix equal, parts of Shore 40 and shore 50, you end up, with shore 45.
Along with the black tint, I put a drop or 2 of red in aswell, and it must be a chemical reaction as the tires seem harder, but test the same onnthe durometer.
The tires still look black , but the dust has a rose tinge instead of gray lol.
I have been playing with mixes for a jumber of years now and those are somemof the things I have found.
All the best
Postby strangebrew » Thu Sep 03, 2015 8:04 pm
strangebrew
