Home Racing World • View topic - Rebuilding The Show-Me Speedway (Lake Show-Me)
Re: Rebuilding The Show-Me Speedway (Lake Show-Me)
Postby RazorJon » Wed Mar 02, 2016 11:50 am
looking good Harry, wish I could help, I owe you from when you did mine
Postby waaytoomuchintothis » Wed Mar 02, 2016 12:48 pm
I have to agree that the Porter Cable 690 is more or less the ideal router for many things, with five different handles, lots of bases, plenty of torque, etc. I have one hanging upside down under the deck of my table saw for a router table. But Porter Cable is expensive, and I don't think you can get your money's worth from one by building routed tracks. Its kinda like shooting a shotgun at a cockroach.
Postby waaytoomuchintothis » Wed Mar 02, 2016 1:19 pm
I knew I was going to hear from you on that one, Dave!
Postby HomeRacingWorld » Wed Mar 02, 2016 1:47 pm
Mission critical parts arrived.
Postby SlotCarCorner » Wed Mar 02, 2016 3:47 pm
SlotCarCorner
Postby HomeRacingWorld » Wed Mar 02, 2016 4:27 pm
One thing is for certain, there is always at least one Dum-Dum here in the Skunkworks.
Postby waaytoomuchintothis » Wed Mar 02, 2016 4:42 pm
Is this weekend the days when the fur (MDF) flies?
Postby HomeRacingWorld » Wed Mar 02, 2016 6:06 pm
Might just be. If my 1:1 job allows it, I might just sneak out for a material run.
Postby midmoslts » Wed Mar 02, 2016 6:35 pm
Harry,
That router you picked up is the same model I picked up at Menards when I set out to build mine. Some folks may say that it is junk, but MDF is not hard on a router. Kind of like needing a razor to cut leather, but a butter knife is fine for butter.
That router along with the quality router bits made short work of routing my track. I was nervous about the little 1/8" bit and bought more than one just knowing that I would break one during the project. Never happened. The same bit I started the track with did the job and I'm sure it could do another track the same size.
I agree on the mounting holes. I made all kinds of fixtures for mine when I built my track. Found the plunge to work as well as one would ever need it to for the use. If one were buying a router to build a track, I would recommend this router. If you routed 50 MDF tracks you would not wear it out.
Keep up the fine work and keep us posted. Give me a call if you need help. I don't know how to use those router thingies, but I know how to eat Little Debbies.
midmoslts
Postby waaytoomuchintothis » Wed Mar 02, 2016 7:40 pm
Yes, the main thing about using a router is to limit speed and cut in the proper direction for stability. The big enemy isn't breaking bits, it is dulling them with too much friction heat caused by moving too quickly or cutting too deep on the first pass (usually not the problem with routing slot car tracks).
Postby dreinecke » Wed Mar 02, 2016 11:42 pm
Less router talk and more routing action! Get this thing done!!!
Postby SlotCarCorner » Thu Mar 03, 2016 6:27 am
SlotCarCorner
Postby dreinecke » Thu Mar 03, 2016 6:37 am
One of my all-time favorites - new and improved!!!!
Postby HomeRacingWorld » Thu Mar 03, 2016 7:51 am
HA! This will do!
Mother Nature is all that is holding me back. That and some evil Knight that won't let me pass through the Skunkworks door. :)
Postby chappy » Thu Mar 03, 2016 9:24 am
And the sense of humor is alive and well at HRW.
Loving the build and the banter.
But to cross the bridge to the Holy Rail you must first answer a question......
