SATURDAY, JULY 18 – 2020!
*Mail in deadline – 17 JULY* Need Models In For Time Trials & Photos!
LOG IN or JOIN the new forum and sign up in our proxy thread HERE!
*I have to photograph and make the web page for your car, please have it in by this date. With this long lead time, I am sure that is possible. Thank you.
LIMIT TWO cars per class please!
| INTRODUCTION |
4. – Entry Fee – $5.00. You can simply DONATE HERE for these. If you are sending from outside the continental USA, we will work with that as well.
| List Of Events |
| Our Track – Please click HERE for The Show-Me Speedway
Our track is a 5 x 16 foot, 4 lane, routed MDF. |
This does NOT sand them, just cleans them. The very mild 50% alcohol/water mix does not harm the tires or reduce the shelf life. It does NOT reduce diameter as already stated. I have tested this compound for nearly 2 years and all my cars from prior events are still in 100% performance.
| Race Divisions
1. Sportsman – The standard full fender body styles. We are combining the older classics with modern late models. 2. StrangeBrew Modifieds – The famous modified series. Inspired by the modeling of our own “Strangebrew” Dave. |
APPROVED BODIES FOR SPORTSMAN CLASS – Carrera Classic NASCAR Ford Torino, Plymouth Road Runner, Dodge Charger. *** No Wing Cars *** – Carrera 57 Chevrolet, 60 Plymouth, 70 Chevelle, early release GTO, Mustang – Revell/Monogram Classic NASCAR – Galaxies, GTX, Charger, Fairlanes, Vintage 69 Nova kit – Scalextric -70 Camaro, 69 Camaro, 69/70 Mustangs, Challenger, Cougar, 69 Charger, 72 Torino – Pioneer Charger/Mustang/Camaro – SRP 55 Chevy, 56 Ford, 70 Chevelle, 69 Nova, 57 Nomad – SCX Cuda – MT Racing Resins – 70/71 USAC Racer, 69 Nova Sportsman, 65 Shovelle, Late Model 69 Chevelle. ASA Camaro, Mustang & Firebird – Gunze Sangyo – 57 Chevy hard top, 59 Chevy hardtop – Revell Snap-Tite – 55 Chevy, 69 Camaro, 70 Mustang, GTO, 78 Camaro, Firebird – RMS Resins Nova II, 65 Fury, 65 Galaxie, 66 Chevelle, 65 Impala, 63 Falcon, 67 Cougar, 68 Camaro, 68 Firebird, 70 Challenger, 70 Camaro, 70 Cuda, NEW CHEVELLE & DUSTER – Skunkworks ShapeShifter – Buick LM, 7123 Camaro, AM Camaro, 65 Ford, MA Cuda, New Bodies as available. * If you create your own resin or 3D bodies, please email me for approval. |
This is a special series that could include many different body styles. See the above photo for examples. If you truly want to enter a model in this division, please contact me with your body style idea. I will ask that your common sense should guide you first. Researching the classic modifieds will give you 1000’s of ideas.
Bodies must be as close to 1/32nd scale as possible. Body shapes should resemble the many prototypes easily researched.
American 2 door or 4 door sedans. Example: 40 Ford Sedan allowed. Cut down 57 Chevy Nomad allowed.
Interior: Must have driver, dash, steering wheel, roll cage detail.
Body Clearance To Track: 1/8″ is a good minimum
Body Height: Keep it stock. Original A/B pillars intact, in other words no low rider/rat rod chopped tops.
Body Width: Keep it stock. You can add flares if you want for scale appearance, but no narrowing of the stock body shell.
MAX Body Width: 2 5/8“. This applies to models with flaring. In other words, no wider than the allowed track width which is 2 5/8″
Body Style: American hardtops cars. No convertibles. No Trucks, Vans, SUV’s, Zamboni’s, Semi’s, Street Sweepers, etc. Common sense time.
Body Clearance To Track: 1/8″ is a good minimum. Front spoiler, if used, at 3/32nd. This will make sure the bodies/spoiler do not drag the track.
Must keep all fenders. This isn’t the modifieds.
Interior: Must have a driver, dash, steering wheel, roll cage detail. NO pre-molded lexan types.
Windows: Front needs glass or screen, your choice. Sides and rear optional.
Side Bars: Allowed but cannot be wider than the outer sidewall of tires. (2 5/8″)
Brass/Steel Wire Chassis. From scratch, but forged or stamped brass motor brackets and guide tongues are allowed.
Inline or sidewinder/anglewinder.
Offset motor configuration allowed.
No Slot.it pods or other plastic/3D/hybrid combos.
2 Wheel Drive Only. Only 4 Wheels.
Chassis to Track Clearance: 1/8″ is a good minimum.
MAX Track Width: 2 5/8″ from sidewall to sidewall.
Stagger is allowed. In other words you can run a 15×8 on the left front and a larger size on the right front, just adhere to the width maximum.
Common sense rule – *If the chassis, gearing or body drag on the track? DQ. I will contact the builder and we will see if anything can be addressed to remedy it.
The goal is to create as close of a field as possible.
Click Below To See Wheels and Tire Combos
C.B. Design 15×8, 15×10, 15×11, 15×13
(Insert, Stock Car, 5 Spoke Racing, F1/MOD, & Classic Steel) If insert wheel used, please use an insert 🙂
The minimum size wheel/tire combination is 15×8 with PG 22125.
-22125, 22126 for 15×8
-22166FF, 22168FF for 15×10, 15×11, 15×13
REMINDER! MAX Track Width: 2 5/8″ from outer sidewall to outer sidewall.
Sidewinder/Anglewinder – Open
Motor
SPORTSMAN CLASS – Piranha Motor Only
Modifieds – Piranha – MT5 – SCC JAWS Only
A complete video series on our chassis.
