Late Model Labor Day -2025
Welcome to HRW Late Model Labor Day Shoot-Out 2025
First Feature: SATURDAY –  30 AUG 2025
Second Feature: SUNDAY – 31 AUG
Mail In Deadline 28 AUG
$10 Entry Fee. 1 Car Per Person
USE OUR FORUM FOR ENTRY AND ALL DISCUSSIONS
A double track feature. First race is here on Saturday, second Sunday at MT Racing.
Any donations for this event can be sent here.
This race is based on the new late model body by our own 3A3D brand.
We have made it as easy as it gets to enter this proxy.
Just order the kit with additional parts list – assemble – mail it in.
It is a generic type car based on the current late model stock car series that are being ran all around our great country. This is the type of “Hometown Heroes” racing that we grew up on and still enjoy today.
The body is 3D resin printed and is very close to exact 1/32nd scale.
The kit incudes:
Body
Interior with driver bust
Chassis & Pod
Slot Invasion Guide
LINK TO KIT HERE AT SLOT CAR CORNER
** This is a PRE-ORDER. The expected ship date is early July 2025 ** Price shown is an estimated price and is subject to change.
Product photos show completed cars for illustration purposes. Kits do not include running gear (see description below for more info on additional parts required), paint, decals, glue, etc.. If you are not sure what is/is not included, please ask before ordering.
** Note: SlotInvasionUSA has generously donated the guide included in this kit.
3A3D Asphalt Late Model Kit – 1:32 scale. The kit consists of a 3DP late model stock car body, chassis plate, motor mount ( short can sidewinder), interior, hardware and SlotInvasion guide. Actual kit may vary slightly from photos.
Also included are the following items (“hardware”):
4x – M2 5mm grub screws (oval point)
4x – M2 body mount brass inserts
2x – SCC M2 x 6mm motor mount screws
4x – SCC M2 x 6mm body (machine) screws
2x – SCC 4mm motor mount screws
2x – JK Products #5574 3/32 single flange bushings
4x – .020″ Axle shim/spacers
In addition to the items included in this kit, you will need to purchase front axle assembly, rear axle assembly, slim can motor, and any other items required to complete the build (see list below). If you decide to finish the body and interior, you will need to provide paint, decals, etc. as well.
Parts you will need to complete the kit (not included):
4x – CB Design 15x8mm Stock Car Wheels (2 pairs)
4x – Paul Gage PGT-22125 tires (2 pairs)
2x – 3/32″ x 65mm axles
1x – Predator 22.5K RPM “Jolly Rancher” Ball Bearing Motor
1x – Slot.It 18mm 34-tooth Sidewinder Spur Gear
1x – Slot.It 9-tooth 5.5mm Inline Pinion Gear
2x – Car braid
2x – Motor Lead Wire (6″ ea.)
2x – Motor Lead Wire Ferrules
EXAMPLE OF FINISHED MODEL by Shotgun Dave
Rules:
  1. Must use our SCC 3A3D Kit
  2. Only 15.8 x 8.5 MM CB Design STOCKER or Insert Wheels on ALL 4 CORNERS.
  3. Only Paul Gage Urethane sizes 22125 or 21125 standard shore (not XPG) tires.
  4. Only 22.5K Predator “Jolly Rancher” ball bearing motor.
  5. Your choice gear ratio
Modeling Notes
Body Width: Keep it stock. IN other words: KEEP THE BODY STOCK
Body/Chassis Clearance To Track: 3/32″ is a good minimum. Our track is very slightly banked, so this distance is ideal to prevent front or sides os body making contact. If you assemble the kit without modifying the body mounts, you should have no problems.
Interior: Yep, we provide one. Use it.
Glass: Optional. Some use it, some don’t. Some have front only. Your call.
1. – This is a scale modeling event. The actual modeling and appearance of the cars are on equal terms as performance. Almost any racer can make a car go fast. An enthusiast can make them go fast in style.
2. – Entry Fee – $10.00. You can simply DONATE HERE for these.  If you are sending from outside the continental USA, we will work with that as well.
List of Events
SHAKEDOWN – Test and Tune
Held the Friday before the event. We test every model and report live on the forum. If we find any issues with your model, we will contact you and repair if we can. THis way your model will be ready for race day!
“Best In Show” – The modeling portion of the event where your models will be photographed and a page for them created. Then all the models will be judged by the discerning members of our forum and the results posted.
“FAST LAP Qualifying”. Your models will be timed in one lane and the best overall time winner will be posted.
“The SHOOTOUT!” – The cars will be ran in a rotation format. Drivers will be stationary.
Our Track Info:
Our Track – Please click HERE for The Show-Me Speedway
Our track is a 5 x 16 foot, 4 lane, routed MDF.
Track Surface: Satin Latex
Lane Spacing: 4 Inches
Slot Depth: Shade over 10 MM (any commerical or wood guide will clear)
Straight Length: 10 feet.
Rails: Slot Car Corner tinned copper braid.
Power: 25 AMP DC Adjustable
Control: DiFalco
Timing: TrackMate Infrared hardware and TrackMate software
And the great oval at MT Racing!
TRACK INFO:
6 x 15 Routed Oval, high gloss latex surface.
Non Magnet. 12 VDC Power.
Trackmate Timing.
CONTACT ME BELOW for mailing or PM me in Facebook for better yet, our forum!
